    Hanover, PA
    2002 Corvette Convertible
    Ls1 shuts off after 20-30 seconds.
    OK, so here is the situation. I installed a LS1/4L60E from a 2000 Camaro into a 1946 Chevy pickup street rod project. I'm using a Painless Performance #60608 wiring harnass which incorporates the LS1/4L60E into a street rod chassis harness. The harness came with a free computer reflash which has already been done.
    The engine started and ran fine, but after 20-30 seconds the engine shuts off. If I wait for a minute, it starts right up and runs for another 20-30 seconds. I did notice that when the engine begins to die, the fuel pump relay begins to kick on and off then goes off completely. I wired the fuel pump directly to the battery but it still does the same thing. I assume that when the fuel pump relay begins to kick on and off, I'm losing spark and or the fuel injectors also. Any ideas on where to look next?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The fuel pump relay should never click on and off while the engine is running. Wiring the fuel pump directly to the battery should have solved that problem but apparently it didn't.
    The spark ignition system and fuel injectors are on a different relay and should not be affected by the fuel pump relay. The fuel pump relay should only be connected to the fuel pump.
    You problem does sound exactly like its running out of fuel. Maybe there is something wrong with your fuel pump or something else inside the tank. Or maybe your fuel filter is bad, clogged?
    Junior Member Raptor Avionics's Avatar
    Aug 2009
    Elmendorf AFB, Anchorage AK
    RED (M6)
    2001 Camaro SS 13.39@106
    This may sound WAY left field but... I once had the exact same problem and it ended up being the chip in my key sending the signal through the steering coulmn harness (basicaly a security feature shutting off the motor). Being as you have done a swap I understand you may not even be dealing with this sort of set up. Just thought i would put it out there.
    Hanover, PA
    I really don't think it's a fuel pump problem because when I wire the pump directly to the battery the pump continues to run and the pressure is good even when the engine shuts off.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by Raptor Avionics View Post
    vats shouldnt be on his old street rod....
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by radiowaves88 View Post
    i know this is incredibly simple ..but have you replaced the relay ?
    Aug 2009
    RED (M6)
    I agree, just throwing something out there that might have been overlooked
    Member 20ws6speed01's Avatar
    Jun 2009
    Winston,OR
    blue
    2001 WS6
    ASD relay
    what is on that relay as pre diagram?? Is it ur Auto Shut Down relay??
  1. Engine shuts down after startup
    By rjmonty in forum Computer & Tuning
    Last Post: 03-18-2009, 01:27 AM
  2. Help: Car randomly shuts off???
    By iceman504 in forum General Help
    Last Post: 04-14-2008, 05:49 AM
  3. Internet explorer shuts down?
    By redls1 in forum Computers / Gaming
    Last Post: 12-23-2007, 03:31 PM
  4. Ws6 backfires and shuts down at 5000rpms
    By 30th t/a in forum Computer & Tuning
    Last Post: 10-20-2007, 07:28 AM
  5. Z28 Randomly shuts down...
    By Kamauxx in forum General Help
    Last Post: 08-15-2007, 02:47 PM
