08-15-2010, 06:44 PM #1Senior Member
- Apr 2008
- Madison, WI
HpTuners tune locks out EFILive tuning?
Anyone know if there is a circumstance where a car tuned with HpTuners won't let another tuner use EFILive to retune the car? Or vice versa? A local tuner here says he can't tune this car in question (a GTO) because of this. He says the tune isn't locked and I'm hearing this all from a 3rd person.
If so, what the solution? He (and the shop) are asking me (and the 3rd person) to use GM service programming to put it back to stock so he can tune it or possibly borrowing my laptop with HPtuners so they can tune it.
08-15-2010, 07:02 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I have heard that HPT can be locked. Maybe EFILive isn't compatible with HPT?
08-15-2010, 07:22 PM #3Senior Member
- Apr 2008
- Madison, WI
I was under the impression that you could go back and forth between the two without issues unless the tuner locked the tune.
08-15-2010, 07:48 PM #411 years of bangin gears
- Jan 2009
- North Jersey
I dunno the gist of things, but when I had mine tuned, it was discovered that my car had LS1Edit and my tuner had to upload the stock tune and upload the HPTuners to make the adjustments.
08-15-2010, 07:50 PM #5
you can go back and forth unless someone locked the pcm.
08-16-2010, 05:17 AM #6Senior Member
- Apr 2008
- Madison, WI
aaahh...I think I may have found a possible answer while searching. If this GTO has a different HpTuners operating system loaded into it, then its possible EFILive won't work with it.
For example, HPtuners offers 2 and 3 bar operating systems for boosted engines and I bet EFILive doesn't recognize it. I don't know enough about this GTO yet to say if that might be the case.
08-16-2010, 08:27 AM #7
COS's are locked to other suites to protect the intellectual property of HPTuner's and the work they did on their custom OS's. ANY HPTuner's owner can readily read and write the PCM though.
Wanted: HPtuners or EFIlive for single car...
By cjfast in forum Parts Wanted / TradeReplies: 1Last Post: 03-06-2010, 08:45 PM -
Home Tuning EFIlive v2
By ls1hoon in forum Computer & TuningReplies: 3Last Post: 08-10-2007, 07:27 PM -
anyone here that can help me tune my efilive??
By camaro4me in forum Western MembersReplies: 0Last Post: 06-17-2007, 05:11 PM -
efiLive AutoVE Tuning on LS1 t/turbo
By lplott in forum Computer & TuningReplies: 8Last Post: 03-27-2006, 12:52 PM -
By lplott in forum Forced InductionReplies: 2Last Post: 03-15-2006, 02:17 PM
