Results 1 to 13 of 13
Thread: knocking noise
08-11-2010, 05:02 PM #1
knocking noise
hey guys my cuz has a 01 bird M6 he's only 18 and is a little ruff on it.
well he had a fight with his mom left the house over rev'ed the car leaving rubber and now has a knocking noise from the rear of the motor(passenger side) i already took all the push rods out to make sure he didnt bend one there all fine,rockers are fine,rollers feel ok,valves are straight .....any info will help so what do you think i just hope its not a rod bearing because im the one who has to fix it.....
08-11-2010, 07:15 PM #2Junior Member
- Dec 2007
- Austin, TX
Pewter- 2002 Trans am WS6 T-top
How can u tell if valves are straight, without compression test. What type of mods on engine. What does oil look like? Only a couple of things it could be. Crank bearing/rod bearing. If you look at this way, if the engine has stock internals then there is nothing for any thing to come in contact with each other.
08-11-2010, 07:44 PM #3
I'd say a spun bearing or a lifter took a shit on you.
08-12-2010, 12:09 AM #4
With the rockers off all the valves are sprung shut an through line of site they look straight plus I put a straight edge on them. Also there is no smoke when it's running. Mods are LT headers an ORY
08-12-2010, 06:04 AM #5
08-12-2010, 01:24 PM #6
How do I post a audio. It's loud enough to hear over the headers. And it's only heard when you rev it a little. The litters push rods and rockers are all fine
08-12-2010, 01:56 PM #7
No offense, but STOP running it.. If it is a bad bearing you could do more harm than good.. Drop the pan and have a look see bro.. You'll know pretty quick if that's the problem.. My guess is that it is a spun bearing.. You don't need valve/head damage to go along with your troubles brudda..
08-12-2010, 02:18 PM #8
08-12-2010, 03:23 PM #9
Might as well just take the engine out at this point... no matter what it is, you will have to take it apart... if it spun a bearing, the crank will need turned. If he broke a rod bolt, the rod will need replaced...
GM EFI Tuner
2002 Trans Am WS6 - 9.41@143mph, #3675, on pump gas and drag radials - sold
08-17-2010, 08:17 AM #10
all this over a fight with mommy.
"Life is to short to drive a slow car"
Gone but not forgoten: 1998 Pontiac Trans Am M6 "The Black Bandit"
Bought- 11-18-05
Sold- 10-14-08
08-17-2010, 08:19 AM #11
My original motor had a spun bearing and it had a very loud knocking sound too. I decided to buy a 6.0 short-block instead of rebuilding the damaged 5.7 block.
08-17-2010, 12:27 PM #12
Ya all this over a fight with mommy. An then someone told him to drive it till it dies and he is I tried to tell him not to. But he thinks he can kill it then rebuild it. Let's see what he says after he puts a new dip stick hole in it from throwing a rod.
08-19-2010, 01:41 PM #13Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Cut open the oil filter and see if any bearing material is present......
Help: Knocking noise
By 2000dreambird in forum Internal EngineReplies: 8Last Post: 11-01-2010, 03:54 PM -
knocking noise?
By jonathans873 in forum General HelpReplies: 16Last Post: 12-28-2007, 10:59 AM -
knocking noise?
By wicked illusions in forum Internal EngineReplies: 8Last Post: 06-16-2006, 10:46 AM -
knocking noise?
By wicked illusions in forum General HelpReplies: 7Last Post: 06-08-2006, 11:21 AM -
98 knocking noise
By daas5 in forum Almost Anything GoesReplies: 11Last Post: 05-01-2006, 06:10 AM
