    Feb 2006
    Broken Arrow, Oklahoma
    Question Blowing 20amp Fuse after header install
    I have a 2000 Camaro SS. I just had headers installed. Cats went away and rear O2 sensor code disabled. Front O2 sensors were spliced/lengthened. Problem is, the 20amp fuse for ENG SEN keeps blowing. This fuse protects MAF, heated O2 sensor, skip shift solenoid, reverse lockout solenoid and the brake switch. I also get a low (2.32) reading with my MAF when the fuse blows, but the engine seems to run fine. Any ideas?
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    I would definately suggest looking for a short, headers might have burned through a wire insulation, or maybe something to do with the splicing of the O2 sensor wires.
    Senior Member
    Jacksonville, FL
    Yep, look at the 02 wiring - friend of mine had the same issue.
    T-Town
    02 Pontiac Trans Am WS6
    Mine did the same thing on the passenger side header, it would short and pop the fuse.
    Feb 2006
    Thanks for the good advice from all of you! That's kinda what I thought it might be, but it always helps to have the opinion of folks that know what their talking about...
  1. Keep blowing a fuse
    By bostonbruins34 in forum General Help
    Last Post: 02-11-2011, 03:25 AM
  2. A/c Fuse keeps blowing...not sure why
    By freshadenamufcka in forum General Help
    Last Post: 06-20-2008, 03:24 AM
  3. blowing fuse
    By guy in forum General Help
    Last Post: 05-01-2007, 07:11 PM
  4. FUSE keeps blowing?
    By First Spray777 in forum General Help
    Last Post: 04-23-2007, 05:45 PM
  5. Ran out of gas, now I'm blowing a fuse
    By Skitzo Gryphon in forum General Help
    Last Post: 12-19-2006, 10:58 PM
