    Junior Member CobraKilla's Avatar
    Monroe,Michigan
    2000 TA LS1 A4w/ShiftKit
    UMI Double Adjustable Pan hard bar
    After my install of my Koni SA's and Strano Springs all the way around this weekend..I am going to try to tackle my Umi Double Adjustable Pan hard bar with relocation bracket next weekend...I was wondering if anyone could give me any good to know tips on this installation. Also was curious if anybody had any input on how to center the rear once the new Pan hard is installed.
    I know after my install of the Koni's and Springs all the way around I am going to need a 4 wheel alignment...Should I wait to get it aligned until after i get the pan hard in and rear centered ?
    Member xmarkx's Avatar
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    phb comes with instructions
    Monroe,Michigan
    Ill have to look again but I didnt see any...Maybe they got mixed up in the packing in the box.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    To center the rear, you can tape a piece of string with a weight to each fender at the same location. Measure the distance from the string to the wheel. This will tell you how far to one side the rear is sitting. Adjust accordingly.
    You can put the PHB on before you get your alignment.
  1. Adjustable pan hard bar.
    By 02sunsetorangeZ in forum Suspension and Handling
    Last Post: 07-10-2010, 10:42 PM
  2. Single or double adjustable?
    By One_Bad_TA in forum Suspension and Handling
    Last Post: 04-09-2009, 04:03 AM
  3. Single VS Double Adjustable VariShocks Pros & Cons
    Last Post: 02-24-2009, 09:00 PM
  4. Koni yellow DOUBLE ADJUSTABLE
    By darkness in forum Parts For Sale / Trade
    Last Post: 06-28-2007, 06:29 PM
  5. QA1 Double Adjustable Shocks?
    By KiD WiCKeD in forum Suspension and Handling
    Last Post: 05-07-2007, 04:13 AM
