Thread: optimum battery
    Junior Member billyb's Avatar
    seminole fl.
    2002 firehawk
    optimum battery
    hi has any one cut off the two top terminals on the red top battery, i want to put a battery cover but with the top post ???????? so has anyone just cut them off. thanks.
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    I found a battery cover off ebay for the Optima red top battery and just painted it to match my other covers.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    I just read something the other day about Optimas and Jeep winches-Optima wants all high amperage loads (like winches) connected to the top posts of the battery instead of the side terminals. The top posts are more closely connected to the plates of the battery and the side posts are connected off of them(the top posts). So ,knowing that,if you cut off the top posts you would have to do that in a way that you don't damage the connection to the side terminals, and don't use the battery for really high amperage loads because the side terminals can't handle it. Hope this helps.
    seminole fl.
    2002 firehawk
    optimas batt.
    hi guy's thank's for the input. i guess cutting the terminals is not a good idea, so i hope i can find that batt cover on e-bay !!! (any link) thank you billy
    WA State
    2002 Z28
    Go to ebay and type Optima battery cover, should come up.
    No 55mph 1QuikWS6's Avatar
    USA
    2000 WS6 Trans Am
  1. Optimum pre-load for LS7 lifters ?
    By Blue28 in forum Internal Engine
    Last Post: 02-10-2011, 06:43 PM
  2. Optimum No Rinse; Field Test
    By third_shift|studios in forum Showcar and Detailing
    Last Post: 11-18-2009, 12:22 PM
  3. Optimum PE table for LS3?
    By Larry in forum Corvette
    Last Post: 06-13-2009, 12:28 PM
  4. **NEW** Optimum Polymer Tech Products for 2008
    By Chris(NJ) in forum Showcar and Detailing
    Last Post: 03-15-2008, 10:41 PM
  5. Optimum air/fuel ratio?
    By SS#1531 in forum General Help
    Last Post: 10-03-2006, 09:25 AM
