Results 1 to 16 of 16
Thread: Wet Floor Pan
    Aug 2010
    Illinois
    Unhappy Wet Floor Pan
    Hi my name is Greg. I am a new member as of today. I love it. I need help if any one has any info for me it would be greatly appreciated. I have a 2000 Camaro SS. I have a problem with water leaking in under the dash it appears from the passenger side. Everytime it rains i find the carpet on that side soaked. It doesnt appear to be leaking from the window seals,they look good. it looks to be under the dash around the heat/air blower motor. Has anyone here had this problem or knows of someone who has. Please Help.
    there's a drain hose that runs down right in front of the passenger firewall. That's probably plugged up. Run a coat hanger through it a couple of times and I bet that fixes your problem.
    Aug 2010
    Illinois
    Wow, Thanks for the fast responce. I took the PCM out and cleaned all the leaves and crap from under it but did not see a drain hose. can you be more specific or maybe another jesture.
    you have to get under the car and it drops down right in front of the passenger side firewall
    Aug 2010
    Illinois
    I see a hole under the heater core/evap core housing but no drain hose. Maybe thats my problem. Do i have too take the dash and heater core housing apart inside the car too replace the hose? I tried to look in the hole but could not get close enough too it. Thanks for helping me out with this issue this website is the shit. I will continue too probe the inside and let you know what i find.
    Senior Member
    Jacksonville, FL
    Are you guys talking about the AC condensate drain or something else?
    Aug 2010
    Illinois
    I do beleave that is what orion had in mind. Do you have any thoughts on this issue I am having. I would love to here all.
    Senior Member
    Jacksonville, FL
    This is the AC drain no external hose: http://shbox.com/1/a_c_drain.jpg In your original post you said it only happens after raining - unless that's the only time you use your AC I was thinking something else, like the grommet under the PCM leaking from pooling water and leaking into the car.
    Aug 2010
    Illinois
    That is exactly what i see. Yes it only happens when we have a good rain. I checked the groment under the PCM a little soft but not damaged or torn. I will check too see if the water could be running down the wire harness that feeds through it. Seems too be tight. Any other thoughts.
    Senior Member
    Jacksonville, FL
    I ran my SLP fan switch wires through the grommet years ago, sealed it with some silicone caulk. Never had any issues. Might be time to get the garden hose out to track it down, if it's not the drain. Is the drain leaving a puddle under the car after running the AC?
    Aug 2010
    Illinois
    you know it. already started on that. But need another set of hands to spray hose while i work my way under the dash to find source of leak. Thanks guys for all the good thoughts. I also have a issue with a fuse that keeps blowing. it would pop every now and then. But did a nice burnout with a slight wheel hop and what ever it was is now a grounded short. I replace the fuse and it will blow instantly. The fuse is for instrument panel lights & parking lights. I need a wiring diagram that shows me the fusebox and destination of all wires. Any ideas.
    Quote Originally Posted by fan4LS1 View Post
    good place to start is the sockets for these. Fairly common for them to corrode.
    As far as the condensation drain I just assumed there was a hose under there. I had the same exact problem you're having with our old GTP and that hose was plugged up....actually, it was plugged up in the firewall area. When it would rain it'd put an inch of water in the passenger floorboard.
    Apr 2010
    Oklahoma
    2000 Camaro SS slp #4161
    If it soaks the floorboard only after it rains, you should look at the grommet that seals the firewall and the evaporator core. When rain runs down the windshield it drains down the corner of the cowl and is directed into the engine compartment. there is a groove it follows from there and water flows between the firewall and the fender wall under the pcm and ac evaporator core. The seal is right by this nwater drain route and the factory did not always line up this gasket perfectly allowing water to come into the cabin. A solution would be to replace this gasket but that is a pain cause yopu have to take apart most of the underside ac works of the dash. A quick fix is run a bead if silicone sealant next to the inside evaporator core where it meets the firewall, you cannot get to it from the engine compartment. Good luck.
    Junior Member BIGGDADDYWIGGS's Avatar
    Martinez Ga
    Blog Entries
    2
    Triple Black
    2002 Ram Air Trans Am
    Another fix is if you look under your floor pans you will see a rubber plug, do like I did with my Convertible which had water pooling in the backseat area from plugged drain tubes, I just removed them and left them out that way the trapped water would run out and if any future water got in there it would not pool up.Don't cha just love these leaking f-bodies, they are a Love-Hate Relationship.
    Pittsburgh
    2008 Hummer H3
    There's no hose behind the PCM along the fire wall, just and area for water to escape.
    Just clean out all the debris that gets caught up in there from time to time.
    If that does'nt solve the issue then you may need to pull the cawl cover under the wipers and clean out any debris that tends to build up below the corners of the wind shield.
    The HVAC blower breaths from the cawl if the cawl rain drains are clogged with debris rain water can build up and enter the blower housing draining onto the floor inside the car.
    This is eerie, I have this exact problem and was beginning to search the site and here it is on first page....
  1. AC only blows to the floor?!?!?
    By chris5 in forum General Help
    Last Post: 10-16-2009, 04:18 AM
  2. pedal 2 floor
    By petercar06 in forum Manual Transmission
    Last Post: 04-28-2008, 11:07 AM
  3. where can I get floor mats?
    By patriot1136 in forum Firebird / WS6
    Last Post: 04-04-2008, 12:00 PM
  4. WS6 Floor mats
    By kwade in forum Appearance Section
    Last Post: 02-20-2008, 09:48 AM
  5. WTB 97-99 TA Floor Mats
    By 9c1ny in forum Parts Wanted / Trade
    Last Post: 02-14-2008, 04:56 PM
