Results 1 to 17 of 17
Thread: My newest new toy
08-03-2010, 06:57 PM #1
My newest new toy
Got my newest toy this afternoon. Its a Stag-Arms Model 15 AR-15. Never been shot. Came with 4 magazines, sling, bi-pod, and a scope.
With the scope:
Looking for new glass as we speak. Just want something a little smaller.
08-03-2010, 07:38 PM #2
What kind of glass and power are you looking for?
08-03-2010, 07:54 PM #3Senior Member
- Apr 2010
- Alpharetta, Ga
04 Cobra 'vert - M6 mysti- 02 WS6 coupe - A4 red
Ideal for home defense!
Just kidding, I can't remember now which movie that's from... But I would love to have a chance at that on the range.
08-04-2010, 07:27 AM #4Member
- Sep 2008
- Kennesaw, GA
Silver- 2005 Toyota Corolla (DD)
I need to replace my fixed carry handle with a flat-top reciever...
08-04-2010, 06:32 PM #5
08-04-2010, 09:12 PM #6
I have a Stag lower on my AR. Keep an eye on your hammer and trigger pins. I had my trigger pin work it's way out on me, caused the trigger to sit a little sideways inside the lower and i could not fire. It's a common problem with Stag's lowers from what I hear. I replaced the pins with the dogbone non-rotating pins from KNS Precision. Cost is $32, not too bad, but they'll prevent a headache, if not worse. Just a heads up. Congrats on the rifle, I'm quite fond of AR's.
Here's a link -
http://www.knsprecisioninc.com/mm5/m...ory_Code=NRTHP
Here's a pics from AR15.com -
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
08-05-2010, 07:03 AM #7Speak the truth
- Apr 2006
- Charlotte, NC
Hugger Orange/W stripes- 1999 Z28 M6
I guess I should have read this before I posted on the "Question for Sarge" thread.
Good luck with your rifle!!!
08-08-2010, 12:50 PM #8
08-09-2010, 10:01 PM #9
I believe I remember that Stags did have a problem with spring tension which caused no fire. Stag got fancy at one time and had lessened the trigger pull weight by lightening the hammer spring which in turn caused a problem with primer strike. I think the replacement hammerspring was a Colt mil-spec spring and the problem was solved.
Unless you are competitive shooter and have the work done by a professional, I'd stay with a mil-spec trigger group.
Some advice to help break in of the bolt carrier group is to remove the carrier, shoot little Break-Free CLP around it, re-install it, then pull the charging handle back and forth about 200 times. DO NOT let go of the charging handle. Just pull it back and ride it forward fast, back and forth. Now you have metal shavings around the bolt carrier and upper from wear points. Clean the weapon. It's much better to do this first than going straight to the range and fouling/scarring up your barrel with shavings.
Just adhere to the owners manual for barrel break in. A lot of differing opinions out there.Last edited by Huskerz1; 08-09-2010 at 10:03 PM.
08-10-2010, 04:27 AM #10
08-10-2010, 08:21 AM #11
Doubt that. It's all Colt from the factory. No doubt that cmt makes a hammer spring tho. However, cmt for years was an oem vendor for other gun companies.
Actually, cmt and stag are 2 different companies. Dad owns cmt and his son stag.Last edited by Huskerz1; 08-10-2010 at 08:27 AM.
08-10-2010, 02:13 PM #12
08-10-2010, 09:53 PM #13
Don't get assholly on me. The Stag name is bigger and therefore more marketable at this point. However, they are separate companies like I said. cmt makes parts and packages then under the Stag name as of this typing.
Even tho we're getting off tangent here, I see no proof/link to what you speak but anything is possible I guess. I know that cmt/stag makes uppers, lowers for other vendors. Colt doesn't sub-contract it's neutered bolt carrier group(Stag has a M16 style bolt carrier that covers the firing pin) so I can't see Colt sub-contracting out the internals of it's lower. A bare lower from a machine and tool company, ok. I think tomorrow I'll try to place a call in to Colt and just see what's what anyhow.Last edited by Huskerz1; 08-10-2010 at 10:27 PM.
08-11-2010, 03:36 AM #14
You really think Colt is going to tell you who they get their parts from? The definately get their receivers from CMT and I'm pretty sure most of their small parts as well. They get barrels from ER Shaw. Not sure who makes their BCG's could be made on site but I doubt it. Once again like I said CMT and Stag are one in the same. CMT supplies parts to most of the AR industry in some form. Stag is the name they use to market their own products to the public directly.
08-11-2010, 10:39 AM #15
Yes I do and yes they did. I called customer service(800-962-COLT) and was assured (after a brief fact check by the agent) that Colt's hammer spring was MADE there in the Conn. factory. I brought up cmt/stag and the answer was no. Now, if the after the rifle left the factory and needed some work done, Colt uses a company called "Specialized Armament". Whose to say what vendors approved by Colt supply them.
I have no doubt that cmt supplies the most parts in the AR industry. Replacement and aftermarket.
08-12-2010, 05:41 AM #16;)
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
Tht movie would be "the Terminator". When Arnold goes into the gun shop to arm up for the hunt.
Nice rifle! An Trijicon ACOG would be a bit smaller and more adaptive for you maybe. They have several models to choose from or you could get a nice CQB/field site called the EO-Tech. The EO-Tech is personal favorite!
08-15-2010, 08:03 AM #17
the newest k&n add
By b.lee in forum Almost Anything GoesReplies: 23Last Post: 08-29-2007, 08:19 PM -
my newest mod to car
By silverz98 in forum Southern MembersReplies: 4Last Post: 10-18-2006, 05:55 AM
