Thread: Headliner is falling HELP!
08-03-2010, 05:56 PM #1
I could use some suggestions since I've never had a bad headliner before. The headliner in my ss is partially falling, I do have t-tops. The headliner looks good but the whole board has dis-attached itself except where the plastic thing holds it up in the middle and of course where the visors are screwed in. Any suggesions i dont know how to make the board stick up again, is there a product i can use. Even if I were to get a whole new one, how does it work if there is only one plastic holder thingy majig????
08-05-2010, 06:04 AM #2
08-06-2010, 07:04 PM #3
Is it the material that is sagging, or the headliner board itself? A pic would help.
08-07-2010, 12:49 PM #4
Its the whole board, the material is in tact with the board and it is falling up by the windshield and all around the t-tops i unfortunately didnt set up phtobucket yet. Someone told me there is a pray but i thought that was just for when material is sagging?
08-08-2010, 09:12 AM #5
Permatex makes an interior trim and carpet adhesive.
Never used it to hold the backer up, but it works great on the headliner fabric.
Just spray it on both surfaces and let it setup for a minute before you stick the 2 together. It would support it with a board while it dries.
Leave the windows open while you spray it and while its drying. It stinks pretty bad.
Good Luck!
08-08-2010, 08:41 PM #6
The front is held up by the a-pilar panels and the sunvisors. Is the panel sagging in the middle? Check around the sunvisors and make sure it hasn't pulled through.
08-09-2010, 11:12 AM #7
Thanks for the info on the spray and yes it is sagiing right in the middle up by the rear view mirror the only thing holding it on is the button in the center between the t-tops and the sun visor screws. I thought maybe there should be another button up there by the winsheild and rear view. What usually holds it up there?
08-12-2010, 05:38 PM #8
As far as I know, nothing- It's held up at on the outside corners by the pillar covers, the sunvisor mounts, the interior light, and the plastic clip.
Falling Skies...
By 67CamaroRSSS in forum Almost Anything GoesReplies: 5Last Post: 07-03-2011, 08:20 AM -
Headliner
By 02blckws6 in forum Parts Wanted / TradeReplies: 0Last Post: 10-21-2010, 06:20 AM -
Help: What is falling off my car?
By kool-aide in forum General HelpReplies: 15Last Post: 10-09-2008, 04:06 PM -
WTB new or used T-Top Headliner
By gfeller2006 in forum Parts Wanted / TradeReplies: 1Last Post: 08-28-2008, 08:37 AM -
headliner
By kristen in forum Parts For Sale / TradeReplies: 0Last Post: 12-05-2005, 05:38 AM
