Results 1 to 3 of 3
Thread: Radiator cap question
08-02-2010, 11:30 AM #1
How do you remove the radiator cap on a 98 Z/28? Also- where is the sensor for coolant level? Last- how do I make sure there is no air in the system after flushing it and refilling with dex cool?
Thanks in advance.
08-02-2010, 04:01 PM #2
Ensure the engine is cool and press down and rotate counterclockwise, to "burp" the system, start the car with the rad cap off and allow it to cycle and get to Op Temps and top off fluid. Coolant level sensor is on the passenger side of the radiator, the only sensor on there.
08-02-2010, 10:35 PM #3
Thanks for the reply! I found out- My Rad cap is a bit different-you turn counterclock without pushing till it stops-then continue turning counterclock while pushing down- I never had a cap like this before-all my others came off like you said.
Thanks for the sensor/burp info-very helpful.
question about radiator/ac condenser on my 96 LT1
By krese in forum LT1Replies: 2Last Post: 03-21-2011, 06:43 AM -
Replacement Radiator Question
By whytry2002 in forum LT1Replies: 8Last Post: 10-22-2010, 02:31 PM -
Radiator question
By Ramairgod84 in forum General HelpReplies: 3Last Post: 12-04-2009, 08:19 AM -
Radiator question
By Art99SS in forum General HelpReplies: 3Last Post: 08-27-2009, 09:53 AM -
Radiator question
By 98Camarod in forum General HelpReplies: 0Last Post: 08-23-2006, 10:43 AM
