08-01-2010, 11:48 AM #1
Twin Turbo Kits for 2010 / 2011 Camaros
Granatelli Motor Sports in concert with Turbo Technologies, Inc have come up with the first truly bolt on twin turbo kit worthy of the demands of the LS3 and L99 engined Camaro. Using twin PTE6265 Precision Turbo turbochargers, combined this system will support 1300hp at the crank. However, at only 7.5lbs it makes 640hp and 600 ft/lbs on a M6 trans (570hp and 580 ft/lbs A6) to the wheels and can be driven in bumper to bumper traffic with no worries. All tubing is tig welded and mandrel bent. HUGE 3.5” thin wall aerospace aluminum from the intercooler to the throttle body further dissipates heat and keeps the engine compartment near OEM specified cool. Bottom mount turbochargers draw air from twin sealed 1000 cfm K&N air intakes to insure plenty of flow at all times. Best of all the entire system mounts above the factory frame rails to eliminate the worries of “touch down” over speed bumps a commonly found problem on other systems.
Features and Benefits:
•(2) PTE6265 Precision Turbochargers. – Each capable of 65 lbs/hr
•(2) Turbonetics Turbos Available on request– Each capable of 58 lbs/hr
•Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
•(2) PTE 46mm Waste Gates Insure Maximum Control Over the Monster Turbos
•Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
•Huge 3.5” Plumbing from Intercooler to Throttle Body Eliminates Lag and Increases Plenum Area
•Factory Silver Powder Coated Tubing – Special Colors Available on Request
•Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
•50mm Tial Blow Off Valve
•(8) 62 lb/hr low impedance injectors
•(8) NGK TR6 or TR7 Spark Plugs - Please Specify
•Full Stainless Steel Hot Side Piping
•Largest Front Mount Intercooler Available
•Dual In / Single 3.5” discharge
•Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
We realize that every manufacturer will tell you their kit is best. We simply recommend you ask a friend. Ask your friend who is the only company that offers true bolt on turbo systems for most LS series engine applications. Ask your friend how many companies can sell you a twin turbo kit, in a box, that promises to fit your Corvette and/or Camaro and make over 1000 proven HP.
Introductory pricing - $7995.00
Ball Bearing Turbo Upgrade for PTE $1200 or $600 for Turbonetics
Tuner kits available for $7695.00 (no injectors or Flash tool)
These kits will sell for $8595 after the intro pricing and they will still be the best bargain.
For more Information and to place orders contact Granatelli Motor Sports 805-486-6644.
08-01-2010, 12:02 PM #2
08-01-2010, 12:17 PM #3
08-01-2010, 01:39 PM #4Impounded
- Dec 2007
- SAN FRAN SISCO BABY
VW BEETLE W/ FLOWER- 88 CRX
that is freakin sweet. nice job. hope someone on here with a 5th gen does this and posts some track times.
about how long does it take too install?
08-01-2010, 02:01 PM #5Slow'er'Ass
- Thornton, CO
TTi has some killer kits.
I assume you are just a vendor for them?
Similar to EPP back in the day also selling their kits.
05-17-2011, 05:41 PM #6
RevXtreme's RPE800 Twin Turbo 2010 Camaro Upgrade
By RevXtreme in forum Camaro / SSReplies: 3Last Post: 07-23-2010, 01:15 AM -
2010 Twin Turbo Camaro Kits - Now taking Orders
By Granatelli in forum Forced InductionReplies: 5Last Post: 06-07-2010, 02:28 PM -
2010 Ford Taurus SHO - 365HP Twin Turbo 3.5l V6
By kickflippin1 in forum Almost Anything GoesReplies: 37Last Post: 02-27-2009, 12:56 AM
