Thread: Front Tires wear.
07-31-2010, 03:34 PM #1Junior Member
- Jun 2006
- New Orleans
White- 1998 Pontiac Trans Am
Front Tires wear.
I have a 98 Trans Am. I just went and changed my oil and I noticed that both of my tires on the front are worn all the way down to the steel belt on the inside of the tires. I dont have the stock set up in the front. Only mods are Edlebrock IAS Coil overs not sure if that would change or cause this.
07-31-2010, 03:43 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Are those the same length as stock ones? Could affect it.
My suggestion would be to take it to a shop you trust and have an alignment done - if something like ball joints need replaced, they should tell you that as they usually won't do the alignment then.
07-31-2010, 04:39 PM #3
You need an alignment and ideally dont drive your car except to the tire shop cause your tires can/will blowout and jack up your car.
07-31-2010, 05:59 PM #4
Alignment^
Your camber is to aggressive
08-01-2010, 12:17 AM #5
Ya I would have to agree when that happens it's usually because it wasn't aligned after the new suspension or not done right.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
08-01-2010, 02:18 PM #6Impounded
- Dec 2007
- SAN FRAN SISCO BABY
VW BEETLE W/ FLOWER- 88 CRX
you will need a performance shop that deals with after market suspension.
just getting it aligned at a dealership or firestone will only get it back too the manufacture spec's.
08-01-2010, 05:31 PM #7Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
my car is the same way right now. I need an alignment and i just bought new tires because they have worn down like you stated
08-01-2010, 08:16 PM #8
I just got mine done at NTB and they got it perfect. The one I went to had a good alignment guy. I have BMR drop spings, kyb agx struts, spohn sway bars, umi panhard and lca's and it's sits about 1.25 or so below stock. Had no problem except a little fender roll outback. Did a great alignment.
08-02-2010, 05:03 PM #9
A performance shop isn't necessary with the suspension mods he mentioned. Any competent alignment tech can do it with ease.
08-02-2010, 06:28 PM #10
could just be bad shocks, that'll cause bad wear on ur fronts with incorrect dampening.
08-02-2010, 06:28 PM #11Senior Member
- Mar 2010
- St Pete, FL
if you just have sportlines in the front can they do an alignment?
08-03-2010, 06:43 PM #12
I'n not sure about those last time I had springgs with that mucwas a 89 Mustang and I had to get special camber plates that mounted on top for more adjustment. May need something like that if they make it. Although you may be able to get it close enought. Just see how far tthe specs. are out after they do the alignment.
would my front tires rub?
By 2001-CamaroSS-LS1 in forum Wheels and TiresReplies: 5Last Post: 03-07-2011, 03:25 AM -
I need front tires
By Spikito in forum Wheels and TiresReplies: 8Last Post: 12-23-2010, 08:49 AM -
Question: New Front Tires
By splitfinger09 in forum Wheels and TiresReplies: 10Last Post: 01-24-2010, 08:26 PM -
outer wear on front tires
By anchlo in forum Wheels and TiresReplies: 18Last Post: 10-02-2009, 09:34 AM -
why do my tires wear out quick
By rbrtlux in forum Wheels and TiresReplies: 5Last Post: 02-09-2007, 11:58 AM
