Results 1 to 15 of 15
    Member Dewman's Avatar
    May 2008
    Midland, MI
    2000 Camaro z28
    Window motor or some other issue?
    I searched but i could not find a exact answer. Recently my car has developed a problem with the passenger side window. It will only roll up/down in couple inch increments if i allow for about 30 seconds in between each attempt. This sound like a motor issue or something else?
    Member DaddysZ28's Avatar
    May 2010
    Westland, Michigan, United Sta
    2002 Camaro Z28
    I've been having the same issue with my drivers side window. If i help pull it up with my hand it will go up fine, but if i stop, it will stop itself half way up. the car only has 34k on the odometer, so i didnt think that the window motor would be done already. i read on here somewhere that the windows are way under powered, theres a website posted on here somewhere that makes a kit for it. Would love if anyone else had any suggestions............have a baby on the way so I'm kind of on a tight budget.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Yes it's a window motor. My drivers has been doing the slow roll for a couple years now, I guess I'm just lazy and won't fix it until it gets worse.
    And DaddysZ28, congrats on the new addition!
    Member Thewilldog's Avatar
    Jacksonville, FL
    2001 Z28
    Window motors for both situations. They're good for about 2 years at a time with normal use. I don't think it is so much that the motor is under powered as it is the glass is huge and heavy.
    There used to be a sticky for this fix...
    http://www.ls1.com/forums/showthread...l+window+motor
    Advance Auto Part sells window lift motors with a lifetime replacement warranty. I've taken advantage of that more than once.
    May 2008
    MI
    Light Pewter Metalic
    2002
    I have had to replace four (motors) of this type in three differant cars (all F bodies) Third gen and forth gen. Seems to be a GM issue. The first time you change the motor it's a little difficult because you have to blindly drill through the door inner panel to get to the rivits holding the motor to the regulator. Once you have that done the rest is a piece of cake. Motors are made to fit either side, and they are not that expensive (under thirty bucks)
    This is one of the inconvieniences of owning a F body car....Good luck
    Pittsburgh
    2008 Hummer H3
    Autotrix (site sponser) has an excellent fix for a reasonable price..
    Side note: The sooner you guys stop closing your heavy doors by grabbing the glass, the less problems you'll have with motors and regulators.. My Camaro is now 9 years old and still has the factory reg's and motors and yes they still work...just my .02
    May 2008
    Midland, MI
    2000 Camaro z28
    i dont use the windows to close the doors car was built in 99 so 11+ on stock motor/regulator
    (plus its my passenger window i am RARLY opening that door)
    May 2008
    MI
    2002
    Dewman, I agree with you I don't use the window to close the door either, also it was the passinger side of mine also. I use just enough push to close the door and that's it.
    I don't know why they crap out but, it's not that big of a deal to replace anyway.
    May 2010
    Queens, NY
    2000 Trans Am
    Hi all,
    I had problems with my power windows. The driver side window had stopped working, and the passenger side, would go down normally, but go up real slow. I replaced both window motors! The drivers side works perfect, and the passenger side is exactly the same! Goes down quick, normal, and goes up real slow and at times stops! Any ideas what else it can be?? since I changed the window motors, as well as the window switches.
    Thank you!!
    Urbandale, IA
    2002 Trans Am WS6 (M6)
    Autotrix did the job for me. Both windows were slow going up and after the install both are much better - better than when the car was brand new. I never have replaced the motors.
    Sponsor autotrix's Avatar
    Tulsa, OK
    There are many people that have installed our kit on original window lift motors on their F-bodies and are still driving them with zero window problems.
    My wife still drives a 96 T/A with 207K miles and the window motors are original and fully operational.
    Got passenger window problems?
    http://www.autotrix.net
    **Window Express Down Modules now availible**
    http://www.autotrix.net/products.html
    May 2010
    Queens, NY
    2000 Trans Am
    So I bought the window kit for the passenger side window in August, I got it and installed it back then. Posting videos now, window works great!!
    I'm finally posting the before & after videos!
    View My Video
    View My Video
    Tulsa,OK
    Quick Silver
    2002 Z06
    Great videos! Thanks for putting the effort to make them and post them.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Junior Member mears_ls1's Avatar
    Aug 2010
    ND
    im having trouble with my driver side window only going down half way and then it stops working. and if you give it five to ten min it will roll up or down an inch or two and then stops again... is it for sure the window motor or is it something in the wiring?
    Tulsa,OK
    Quick Silver
    2002 Z06
    98% its the motor. VERY VERY VERY rarely the express down module will die and cause this issue.
    If you want to rule that out, it is easy to bypass it and see if the window works.
    Go here: http://www.autotrix.net/install/
    ON the left you will see Driver Side Express down. Click that then check out steps 19 and 20. That will help you jumper the plug once the module is removed.
    Personally I would just replace the motor though.
    Installing our kit on the passenger side will put both motors on their own circuit and help with premature failure.
    Also make sure you grease the regulator real well when your in there.
  1. Replies: 2
    Last Post: 08-20-2014, 08:39 AM
  2. Help: window issue
    By 2000dreambird in forum Stereo and Electronics
    Last Post: 09-11-2013, 07:04 AM
  3. Driver window issue 2002 Trans Am
    By Jeronimo in forum Firebird / WS6
    Last Post: 03-27-2010, 01:07 PM
  4. window issue
    By phoenix05 in forum General Help
    Last Post: 07-17-2009, 04:59 PM
  5. Power Window and Lock issue
    By GoldenFlame in forum Camaro / SS
    Last Post: 05-07-2009, 04:24 PM
