Results 1 to 13 of 13
Thread: Help me pick my rear end specs
07-30-2010, 01:57 PM #1
- Jun 2010
- Hallsville, MO
Silver- 2002 TA WS6 M6
I've read a bunch of posts.
LINK REMOVED [thanks buddy]
I think I'm going to go with this Moser 12 bolt with the posi.
I have an M6 and most people say go with the 4.10 gears. Agree?
It's a 2002 TA M6 with WS6 package. I want to keep ABS - so which options do I need? The 3 channel or the 4 channel?
Also, which sway bar do I need? Will be mounting to original stock parts. 19mm or 21mm?
Also, any place with the best price on this rear end?
Thanks for you time and opinions guys!
DanLast edited by dgoett; 07-30-2010 at 02:18 PM.
07-30-2010, 02:07 PM #2
- Apr 2010
- Alpharetta, Ga
04 Cobra 'vert - M6 mysti- 02 WS6 coupe - A4 red
psst... you should remove that link, as it's a non sponsor link. The first admin to see it is gonna remove it for ya
But you can certainly describe the part you're looking at from there and get opinions. Just don't link directly to it k...
And for the record, I know nothing useful about it
07-30-2010, 03:40 PM #3
- Thornton, CO
Pass on Moser.
Pass on 12 bolt for M6 if going Moser.
07-30-2010, 05:44 PM #4
Have you considered a 9"? Or a Dana?
FWIW, I have the Moser 12 bolt -- you can see the install here: Bidding my rear adieu! Both the 9" and Dana will stand up to more abuse than a 12 bolt -- especially since you have an M6. Our car is A4 so I was not as concerned. I chose the 12 bolt for its efficiency, lower weight and fitment.
For M6 -- 4.10 is what you probably should go with.
07-30-2010, 06:29 PM #5
- Jun 2010
- Hallsville, MO
Yes, I was going to get a 9" from Midwest Chassis and performance, but he recommended a new drive shaft since mines an m6 and he said the weak point would be the Ujoint adaptor. The price really went crazy went I added posi and ABS and wound up around $3300.
Price for the 12 bolt that I found is $2250 and includes posi and just $100 more for the ABS addon and another $75 for the sway bar. So that comes to say $2500ish and I'm not sure the 9" is worth $800 more.
Got a link to a drop in dana? Haven't looked at that. It's a daily driver with a stock engine and clutch. Might have minor engine enhancements in the future but will never visit a track.
Thanks
Dan
07-30-2010, 07:43 PM #6
07-30-2010, 08:01 PM #7
- Jun 2010
- Hallsville, MO
The 10 bolt in it now has the pinion bearing destroyed and it's banging and clunking horribly. I thought I'd put a stronger rear end in it instead of fixing the crappy 10 bolt. Only has 56K miles on it. Figured the money would be better spent there so I don't just break another 10 bolt.
Am I all wet? I have someone interested in my 10 bolt when I do upgrade it - what would one needing rebuilt be worth? What should I ask for it? A couple hundred?
Dan
07-30-2010, 08:19 PM #8
- Thornton, CO
I don't care for the idea of putting much money into the stocker. Always better to get something bulletproof.
But if you aren't planning on really getting much traction....it would be A LOT cheaper.
Look into Strange 12 bolt's if you are wanting piece of mind but don't beat on it.
Personally, I flog the shit outta my car, so I went Moser 9".
Somewhat regretting the Moser choice, but not the 9" choice.
07-31-2010, 02:51 AM #9
The 12 bolt ran $2,800 when all was said and done. I added a True Trac, 33 spline axles, 4 channel, welded sway bar brackets and relocation brackets.
07-31-2010, 05:05 AM #10
- Dec 2005
- Laurel, Maryland
Moser 9"
Detroit Locker
35 Spline Axles
4.10 Gearing
Relocation Brackets
Fill/Drain Plugs
ABS/TCS Removed
ARP Wheel Studs
$2250 used
08-13-2010, 08:40 AM #11
08-13-2010, 10:42 AM #12
Pretty sure that is what he has on his car....
To the OP, your rear end gear ratio will depend on what you want in the end for your car. If you are leaving the engine relatively stock with just bolt-ons, then yes a 4.10/4.11 set-up wouldn't be a bad way to go.
It really all depends on the set-up you want.
Regarding your question about which ABS to go with, since your car is an 02, it has the 4 channel system, with the wheel speed sensors at each wheel.
You can keep the stock sway bar and mounting with a 9", but it is a pretty tight fit.
02-22-2011, 04:56 PM #13
What is the width of the rear in the 1998-2002 f-body? Just wondering....
Trying to pick up a 3.42 rear in place of my 2.73 rear
By allbaugh_04 in forum DrivetrainReplies: 55Last Post: 03-02-2011, 07:03 AM -
How to pick a rear?
By pajeff02 in forum DrivetrainReplies: 77Last Post: 04-09-2010, 08:20 PM -
Specs on Rear Axle
By KiloVictor in forum Automatic TransmissionReplies: 5Last Post: 07-10-2007, 02:42 PM -
Rear alignment is off after Koni/!= rear isolator lowering, car pulls to right, specs
By anestech* in forum Suspension and HandlingReplies: 13Last Post: 07-08-2007, 09:42 AM -
i need torque specs on rear end!!!!!!!!!
By 02T/AWS6 in forum DrivetrainReplies: 1Last Post: 08-19-2006, 02:35 PM
