Results 1 to 10 of 10
07-27-2010, 09:46 AM #1
Fuel Pump Or Pressure Regulator?!
Okay, ive had this problem for awhile now..what happens is i can almost never start the car on the first "turn". i took it to my mechanic and he said my fuel pressure seems to be fine when its running..but it wont hold pressure for long when its off..he said it might be my regulator and pulled out this little thing from the engine bay lol..but he said he didnt have a way to test it..said he didnt think it was my pump since it holds pressure fine when its on..i dont have any funky idle or nothing..oh and when the car starts..i hear a little screech..kinda like if you slide your foot on a smooth tile floor...cars power is fine..no hesitations i think..so idk. opinions?
Thanks in Advance
-DrewLast edited by TransAmPhantom; 07-27-2010 at 09:49 AM.
07-27-2010, 09:49 AM #2
The fuel pump has a check valve on it I believe. This is what closes to get fuel pressure at the rail so when you go to start it, fuel is ready to be delivered instantly and the car starts on the first turn.
If you are reading good fuel pressure and it takes a few turns to start the car, my guess is your check valve is bad. Not really a concern IMO.
It just takes a few turns because the fuel is being delivered all the way from your pump now b/c the valve is not working properly.
This is how the fuel pump on one of my V6 works anyway.
Try turning the key to the on position for a few seconds before starting the car. I bet it starts on the first turn.
07-27-2010, 09:51 AM #3
Oh it does, what my mechanic told me to do was turn it to on for a few seconds then off then back on for a couple seconds then turn..it does start right away. i was just worried with that screech too lol. im paranoid with this car xD
1992 Black/Gold Bandit Style Firebird (Retired)
1998 Blue/Green Formy A4 (Gone)
2002 Dark Blue Trans Am A4 (Daily Drive)
07-27-2010, 09:53 AM #4
And if i wanted to replace this..how hard would it be? do you know? does it stress the fuel pump more?
07-27-2010, 09:54 AM #5
My 96 Camaro does the same exact thing as you describe. I just had this EXACT conversation with the guy next door to me who owns his own mechanic business. This is how I know haha.
He told me not to worry about it and that it won't affect the fuel pump at all.
My guess is that you would have to drop the tank to access the fuel pump.
The advice I gave you of what to do to start it on the first turn is what he told me to do it it bothered me.
07-27-2010, 11:14 AM #6King 0f n00bz
- Jan 2006
- Shepherd, Michigan
it is always suggested that you pull a "diesel " and before starting the car put the car into the acc position..this gets the fuel up there and helps starts. the sound you are hearing might just be a loud fuel pump priming the system
07-27-2010, 07:25 PM #7
07-30-2010, 11:44 AM #8
Well he pulled something out of the engine bay and said try replacing that first..it was small...and do you think that this is the problem?
07-30-2010, 11:45 AM #9
IT makes the sound when it starts, not when its in the on position. And i always do that anyway =)
08-03-2010, 12:55 PM #10
what he probably pulled from under the hood is the pressure regulator at the fuel rail. totally different part and scenario. I had a similar problem before and cutlass nail it. In my case I had a leak in my fuel tube in the fuel pump.
Fuel pressure regulator q
By grandkodiak in forum LT1Replies: 2Last Post: 08-11-2009, 07:41 PM -
fuel pressure regulator
By Goldcuffs in forum General HelpReplies: 0Last Post: 04-28-2009, 04:36 PM -
fuel pressure regulator?
By 99camls1 in forum External EngineReplies: 0Last Post: 04-05-2009, 05:53 PM -
By pilot_bandit in forum General HelpReplies: 0Last Post: 09-17-2007, 02:26 PM -
Aeromotive A1000 Fuel Pump & A1000 Injected Bypass Fuel Pressure Regulator f/s
By billetss in forum Parts For Sale / TradeReplies: 3Last Post: 05-22-2007, 11:38 AM
