Results 1 to 14 of 14
Thread: 2000 Camaro LS1 - Blue Smoke
07-27-2010, 04:47 AM #1Junior Member
- Jun 2010
- On
- 2000 z28
Hello all, need some advice on what/where to look. 2000 Camaro with the LS1 engine. It smokes blue "sometimes" on start up. When you step on it, you get a puff of blue, but it goes away.
I've put a catch can on it, so ruled out the PCV. I haven't done a compression test, so not sure on that yet. What has me confused is on start up. If it was the valve seals, wouldn't it smoke everytime? If if was a ring problem, wouldn't it smoke steadily on WOT?
Thanks in advance....
Excellent forum!!!
07-27-2010, 06:07 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Not necessarily. As the motor warms up things begin to seat better, oil circulates better, so you may not have oil being burned as much while the engine is warmer. As long as you're sure it's blue smoke and not black smoke, I'd complete the compression test and see what results you get. Do you need to add oil very often?
07-27-2010, 09:40 AM #3
Valve seals are when after it sits because the oil around the valves has time to seep thru and get into the combustion chambers. Rings would make it smoke most of the time. Like knight said, do you have to add oil?
07-27-2010, 10:07 AM #4
07-27-2010, 10:11 AM #5Junior Member
- Jun 2010
- On
- 2000 z28
Thanks to both of you. I use a quart every 2-3k miles. I guess I'll have to bite the bullet and do the compression test. Odd thing though, it doesn't smoke all the time. If it was seals or rings, I would have thought I would see smoke all the time?? Oh ya it's definitely blue smoke!
07-27-2010, 11:47 AM #6
2018 Tahoe - Silver - OEM
07-27-2010, 02:10 PM #7Junior Member
- Jun 2010
- On
- 2000 z28
Thanks, couple more things I should have mentioned ... This happened pretty much overnight and I ended up with a mis-fire on cylinder one around the same time. Does this help at all?
07-27-2010, 05:15 PM #8
Valve seals are a good bet. Start by pulling the pulling the plugs. Generally rings smoke under load, valve seals on deceleration or start up. You should also make sure the fueling is right and you're not washing the cylinders with gas.
Pull the plugs and see what they look like - if they are buring OK, no oil and no soot from being too rich, replace the valve seals.
07-28-2010, 12:51 AM #9
Replacing the valve seals is a pretty tough job I would guess on our cars... Considering the engine placement and such and my limited tool selection... Do you have to pull the heads off? Just in case how much for a shop to do this? Mine smoked once too after sitting for about a week and a half so now I am worried as about my LS1 as usual it seems.
09-04-2010, 11:54 AM #10Junior Member
- Jun 2010
- On
- 2000 z28
Thanks all. Finally did a compression test. It's looking like rings in cylinder 1. All the other cylinders are 155-160. Cylinder 1 is 105, then oil added it bumps to 120. It's starting to use oil now.
So, what do you guys recommend? Can i just replace rings in one cylinder if no other damage? Should I put piston and rings in all? I'm at around 96K miles. What else should I replace if I'm in there?
Not sure of the dollars I'm looking at. Is it going to potentially cost as much as a crate LS1 $2700??
Recommendations?
Thanks again all.....
Todd
09-04-2010, 01:08 PM #11Member
- Jun 2009
- coon rapids, MN
red- 2000TA
maybe do a lite hone with new rings.you can replace the valve seals in car,airing up the cylinder like when you change valve springs.
09-04-2010, 02:36 PM #12Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Mine do the same thing.
Some guys here said it could be the Valve seals. (could be)
But at the shop the mechanic told me. It might need new piston rings.
So I guess it's time to rebuild it
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
09-22-2010, 02:38 PM #13Junior Member
- Jun 2010
- On
- 2000 z28
Update for everyone. I ended up getting a good deal on a used LS1 with low miles. Couple of questions. The LS1 I purchased was from a standard trans car, I have an automatic. What do I need to do? Do I swap wiring harnesses from engine to engine to continue to use my automatic or are there other options? I'm thinking of selling the old LS1, what are your thoughts? Is it worth selling, if so, how much should I ask? The motor will need a bit of work, I'm thinking valve seals and possibly rings?
Thoughts?
Thanks,
09-22-2010, 04:10 PM #14
if your just swapping the motor there is no need for any wiring. Just use your tranny and and components. Drop the 6 speed flywheel and pressure plate. Use what your motor has, torque converter automatic flywheel. I'd say thats about all you need.
Question: black, gray, and blue smoke
By ricekiller65 in forum General HelpReplies: 10Last Post: 05-26-2009, 12:38 PM -
2000 SS Camaro in Navy blue metallic 410 RWHP
By Jays00ss in forum Vehicles For Sale / TradeReplies: 9Last Post: 12-03-2008, 07:32 AM -
blue smoke, HELP!
By john yerxa in forum General HelpReplies: 6Last Post: 06-28-2007, 06:57 PM
