    Sep 2009
    Detroit
    Blue
    1998 T/A air conditioning noise
    Hey guys i was driving my t/a and i had the windows up tops on and my a/c was running for about 20 min while i was driving....when i stopped i heard a very annoying loud chattering noise and i knew what it was from my friends t/a. as soon as i turned the air off the noise stopped but when i turned it on again the engine shut off. when i turned it on the noise was there while the a/c was on again.....suggestions? car has 45,000 original miles
    michigan
    1998 trans am
    I had this happen once two years ago and it has never done it since, I keep waiting for it to return, hope you find out what it is
    Indianapolis
    2000 WS6 6spd Hooker LT
    It could be the AC belt/tensioner (not much $$$), the AC compressor (more likely, and way more $$$), or it could possibly be the fan (not likely, and less than half the $$$ of compressor).
    Or it may have been an abberation, and not come back. Let's hope that is what it was.
    Sep 2009
    Detroit
    Blue
    well it isnt the fan i know that for a fact because when i just turn they key and not start the engine and turn the fan on it sounds healthy and normal and when i turn the car on and the a/c turns on it makes a loud noise like a card in a bicicles rim you know? but even if the engines running and i just turn the fan on it sounds normal HELP!!!
    Sep 2009
    Detroit
    Blue
    well it aint the fan i know that for a fact.....cuz even when the engines running and the fan is blowing (not a/c just the fan) it sounds fine but as soon as i put it on MAX or A/C it makes a noise like a card in a bicilcles rim you know? i dont know what to do
    Jul 2009
    s.a. tx
    navy blue met
    1998 Trans Am convertible
    mine did the same after romping on it with the a/c on. Compressor cant handle high rpm, supossed to cut off around 4 grand but 98's have a glithch and dont do so. Get a new compressor. your sending metal shavings into a/c system if u run it like that
    Jul 2009
    s.a. tx
    navy blue met
    pleeze forgive my spelling and such. been drinkin
    Auto Painter RyanJM's Avatar
    Houston, TX
    Try adding some of the compressor oil charge to it. Quite my Toyota down, it just need some 134 and a can of oil charge and it was food again.
  1. SS Air Conditioning - Need Help
    By 99WickedSS in forum General Help
    Last Post: 06-06-2011, 07:04 AM
  2. Air Conditioning
    By 10spokess in forum General Help
    Last Post: 04-12-2011, 04:44 AM
  3. Help: rear end noise on a 1998 C5
    By Bender10 in forum Corvette
    Last Post: 09-10-2008, 03:31 PM
  4. rearend noise on a 1998 C5
    By Bender10 in forum Drivetrain
    Last Post: 09-10-2008, 01:27 PM
  5. 1998 z28 making noise
    By naulty in forum Manual Transmission
    Last Post: 05-14-2007, 11:41 AM
