Thread: Gutting my cats
    Jul 2009
    Meadville PA
    1998 formula trans am
    Gutting my cats
    Im having problems with my car and I have all 4 oxygen sensor codes coming up so I was feeling the exhaust while it was running and it would go from real hot exhaust coming out to a change of tone in the exhaust to a cold exhaust coming out and not much so Im pretty sure the cats are junk. What do you guys think will happen if I gut the cats out and clear the codes? Should the codes be gone or would the oxygen sensors have been damaged and be replaced also?
    Member 00ls-1's Avatar
    Feb 2010
    Kilgore Texas
    2000 z28
    youll have to tune the rear o2 sensors out as they read what the cats are doing unless you want an ses light. if your state is strict on emmissions then you wont pass inspection with the cats gutted. someone else im sure will post more info if you might have a different problem but it sounds like the cats to me
    Jul 2009
    Meadville PA
    I have an OTC genisys scanner I wonder if that will delete the codes but Im not sure how to I dont know the scanner to well yet.
    Feb 2010
    Kilgore Texas
    2000 z28
    itll delete the codes but if your cats are gone the rear sensors will set it off again shortly after clearing them
  1. complications in gutting an elk
    Last Post: 04-01-2010, 11:38 AM
  2. gutting your cats
    By ldanny in forum General Help
    Last Post: 01-14-2008, 12:03 AM
  3. gutting stock air box.
    By 01redm5 in forum V6
    Last Post: 12-20-2005, 07:44 PM
  4. Cat gutting?
    By 00SilverTAWS6 in forum External Engine
    Last Post: 09-07-2005, 05:18 PM
  5. Gutting the cats.
    By Snake Eater in forum External Engine
    Last Post: 09-05-2005, 11:43 PM
