    Junior Member gigs02ws6's Avatar
    Dec 2009
    Connecticut
    Blue Metallic
    2002 Pontiac TransAm WS6
    Exclamation 02 WS6 TA Clutch Engagement
    Just wondering, my clutch engages high almost at the top of the pedals movement. It has no slippage and engages quick. I am the Second owner of the car with 60,000 miles on it. Is there any type of adjustment that can be made or any other issues which would make it engage so high.
    Thanks
    Next... MrKid's Avatar
    Sep 2009
    Milford, CT
    '68 Camaro RS, '11 Camaro
    There is nothing you can do externally. You may be able to pull the tranny and add some shims. You're lucky. I had a problem with mine engaging almost on the floor.
    Where you from in CT?
    May 2010
    Ohio
    2000 T/A WS6
    i have a 2000 that does the same thing it engages about two inches from the the pedal being all the way out i have 55k mi and just figure ill probably need a new clutch soon
    Indianapolis
    2000 WS6 6spd Hooker LT
    There are some aftermarket adjustable clutch master cylinders available. But for the stock stuff, no, you can't do anything about it. If it is not slipping, then you are ok and it is just how this one works. But usually if it engages high like that and starts getting even higher, then be prepared for a new clutch very soon.
    Dec 2009
    Connecticut
    Blue Metallic
    Quote Originally Posted by MrKid View Post
    I'm From East Haven. Thanks for the reply
    Sep 2009
    Milford, CT
    Quote Originally Posted by gigs02ws6 View Post
    Cool deal...see you at the shows.
  1. 02 WS6 "Clutch Engagement" problems
    By Whamhammer in forum Manual Transmission
    Last Post: 03-28-2011, 05:38 PM
  2. High pedal during engagement of clutch??
    By 91rshoward in forum Manual Transmission
    Last Post: 10-22-2009, 07:09 PM
  3. Engagement Rings
    By RiceEater in forum Almost Anything Goes
    Last Post: 07-23-2008, 05:35 PM
  4. The engagement is off, who gets the ring?
    By AKIRA in forum Almost Anything Goes
    Last Post: 01-29-2007, 05:35 PM
  5. reverse engagement
    By Eddie G in forum Manual Transmission
    Last Post: 10-07-2006, 05:26 AM
