Results 1 to 20 of 36
    Junior Member mxlplx71's Avatar
    Apr 2010
    iowa
    pewter
    what kind of power with this cam
    230/242 .613/.622 115+6
    comp cams 54-000-11 LS1
    50to 60 over stock?
    11.9 with bolt-ons and decent driver.
    Apr 2010
    iowa
    pewter
    looking for rear wheel numbers,
    stock 99 ls1 with lid, lt's, and tune, and this cam.
    400? give me your best guess.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by mxlplx71 View Post
    stick or auto ? why do you care about the numbers ? E.Ts are really the only measurement of speed
    Apr 2010
    iowa
    pewter
    m6, just so i can get a good estimate. im not putting it in till this winter
    Shepherd, Michigan
    98' trans am
    maybe 400-420ish i would guess without stock heads
    Apr 2010
    iowa
    pewter
    im going to try to get heads and a ls6 intake if i can swing it at the same time
    USA
    Velocity Yellow
    2008 Corvette Z06
    maybe 400-420ish i would guess with stock heads
    With the size of the exhaust duration, the torque number will probably be significantly lower than that though.
    2018 Tahoe - Silver - OEM
    Shepherd, Michigan
    98' trans am
    true
    Apr 2010
    iowa
    pewter
    it wouldnt have less than stock though, would it?
    USA
    Velocity Yellow
    2008 Corvette Z06
    No definitely not.
    Junior Member SPDYGON's Avatar
    GEORGIA
    RED
    2001 CAMARO ss
    380 to 390 with can, add heads 420 to 440, add 410gears 450
    all with a good tune.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Are you joking? He doesnt really have anything else done to the car except headers. He still needs an intake,exhaust,ported TB,under drive pulley, oil pump etc...
    You should be more than happy with 370 rwhp. (If you even get that)
    "Life is to short to drive a slow car"
    Gone but not forgoten: 1998 Pontiac Trans Am M6 "The Black Bandit"
    Bought- 11-18-05
    Sold- 10-14-08
    New Jersey
    Quote Originally Posted by SPDYGON View Post
    Gears reduce hp not increase it. The higher the gear, the more hp it eats up.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by rajiv1998 View Post
    Lower gears you mean. (higher #'s = lower gear)
    But I do agree. In no way does gearing the rear end increase hp. It may not eat up much, unless you actually swap the crap shoot 10bolt for a larger rear axle, then you're losing hp due to parasitic loss.
    New Jersey
    You know what I mean
    Shepherd, Michigan
    98' trans am
    he doesnt need a udp, or a oil pump...nor do those really add that much power ...the same goes with a ported tb ...all added up might be 10 to the floor and that is being generous.
    however 400 might be generous ..i see 390 not out of the realm of possibility on a dynometer
    Shepherd, Michigan
    98' trans am
    jesus i see what you are saying. i didnt add "out" ..im sorry..without stock heads.
    New Jersey
    Oil pump wont do anything, but a ported TB and an underdrive pulley will help (even if he does gain 10hp, thats still a decent amount of power for around $250). The main things holding him back are an LS6 intake and a catback/duals.
    OP, install the cam the way the car sits and get back to us.
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Install your cam and run it at the track.
    H.P. numbers don't mean shit.
  1. What kind of power should I expect?
    By WS.6#384 in forum Dyno Information
    Last Post: 09-16-2007, 12:00 PM
  2. What kind of power can I expect with this set up?
    By ericosu84 in forum Internal Engine
    Last Post: 05-20-2007, 05:57 AM
  3. What kind of power can I expect with this set up?
    Last Post: 05-04-2007, 09:02 AM
  4. What kind of power will this make?
    By pyro71985 in forum Internal Engine
    Last Post: 09-15-2006, 06:09 PM
  5. What kind of horse power can I get with V6
    By Chevy 4 Life in forum General Help
    Last Post: 06-04-2006, 08:23 AM
