    Member Badass WS6's Avatar
    Oct 2009
    A, A
    2002 Trans Am WS6
    Question Regarding Cleaning Engine/Engine Bay
    As the title states, I have a few questions. I am wanting to powerwash my motor and the engine bay becuase it's seen cleaner days.
    For those that have done this, what do I need to cover/protect from getting wet. Stupid question, I know. But, oh well.
    Thanks in advance for any help.
    Coral Springs, Fl
    Sunset Orange Metalic
    main thing to cover is the alternator
    plastic bag, tin foil, whatever you can find
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    A wet rag
    yes, that's really it. Don't be surprized if there is still grease and build up though. The pressure washer won't remove everything. you'lll want to physically degrease and brush off the hard spots, then use the PW to hose it away for good once it's loose.
    Lifes A Garden, Dig It!!! 02convertibleT/A's Avatar
    Jun 2009
    Northern Ohio
    2002 Trans Am Convertible
    i use something like a degeraser, but at like 5:1 or 10:1 and a big tire brush. works like a charm! check out the saturn sky detail thread, look how nice it is!
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    Also if you have access to hot water it will help alot. The water we used at my old work was scalding hot and cut engine bay grease like crazy. Sprayed Jax Wax degreaser, agitated it with the brush, then just sprayed it all off with hot water. Worked like a charm.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Make sure the motor is cool. Half the degreaser's say to let the motor run then spray it, but DO NOT DO THAT. I would also cover up the PCM and the area around the coilpacks. Spray the cleaner and let it sit. Then re spray it and clean with a brush if needed. Then rinse it out really good and dont leave the hose in a certain spot for more than a few seconds. Try and blot up as much as possible. Try and see if you can get a leaf blower to get water out of the hard to reach areas. If you cant just take it for a spin and let it come up to operating temp. Let it cool and apply CD2, then close the hood and your all set.
    "Life is to short to drive a slow car"
    Gone but not forgoten: 1998 Pontiac Trans Am M6 "The Black Bandit"
    Bought- 11-18-05
    Sold- 10-14-08
    Junior Member germ89's Avatar
    Oct 2009
    Pensacola fl
    mystic teal
    2000 camaro z28
    ive done pro detailing, when i was detailing an engine bay purple power and wheel acid/cleaner (50/50 mix acid to water) and have the car running at all times and as was cover the altn. purple power first set for 2 to 3 min before starting car spray everywhere then rinse with car on, with car still on spray acid on (mainly on all the metal areas then rinse wright after. comes out looking brand new.
  1. engine/engine bay cleaning
    By Blackbird WS6 in forum Showcar and Detailing
    Last Post: 11-15-2010, 04:39 PM
  2. Question Regarding Cleaning Engine/Engine Bay
    By Badass WS6 in forum Appearance Section
    Last Post: 07-20-2010, 06:22 PM
  3. Replies: 0
    Last Post: 06-01-2007, 10:00 AM
  4. Replies: 0
    Last Post: 04-24-2007, 01:20 AM
  5. engine cleaning
    By roadrashr6 in forum Appearance Section
    Last Post: 04-15-2006, 08:28 AM
