Results 1 to 20 of 23
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Blown headgasket?
    Got a quick question, how can you tell if you have a blown head gasket. Don't worry it's not on my ls1 but my daily driver. Just wanted to know what your guys' suggestions on what I check first should be....thanks for any help!
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    does your engine bay smell like crap? do you see a leak? are you smoking? are you throwing codes? have you done a compression test?
    what does your oil and anti-freezelook like?
    Feb 2007
    California
    2000 Trans Am
    thanks for the quick reponse. I had a lot of white smoke pouring out of the rear of the vehicle..I turned it off immediately and let it sit for a couple of seconds, then tried to turn it back over and just heard a clunk. I have nothing leaking from underneath from what I could see. It had an undescribeable smell....Almost like "smoking breaks" or hot breaks.....
    I didn't have a chance to look Orion as I was on my way to work and had a friend pick me up. But I will check that first thing when I get back to my truck at lunch. Are those the first two things I should check?
    Feb 2007
    California
    2000 Trans Am
    Oh a couple more things....I did add some coolant because I noticed that it was low yesterday, and replaced the radiator cap because it was corroded.....not sure if either of those are significant or not.....to my situation
    Jun 2009
    Saint Louis, MO
    it sounds like you blew it. like orion said, check the oil to make sure it's not mixing with the coolant. that'll be your best indication.
    Feb 2007
    California
    2000 Trans Am
    How hard is replacement? It's an 85 toyota pickup.....what will need replacing? just off the top of your head without looking at the engine of course From what I can gather from surfing online at the least a new head gasket (of course) new spark plugs, new oil, and new radiator fluid.....
    Jun 2009
    Saint Louis, MO
    shouldn't take longer than 9 hours
    Feb 2007
    California
    2000 Trans Am
    Any gasket besides the head gasket that I should think of replacing while i'm in there....and will any of this affect the cylinders, etc......
    this is what kinda worries me.....what do you mean you just heard clunk? Did it try to turn over and stop or did it not do anything? Does it turn over now? Hopefully you didn't hydro-lock it.
    Feb 2007
    California
    2000 Trans Am
    Well Orion, I stopped by where it was during lunch, and looked at the oil cap....oil looks good, looked at the radiator fluid, that looks good, looked at the dip stick and that looks fine. But I did take a look at where the spark plugs are and their is water seeping from them......I tried to start it and it turned over but runs like there's a cam in it....and not the good kind .....either way any of your suggestions would be much appreciated.~Chris
    Member goof4080's Avatar
    Jun 2009
    lisle, il
    Red, Black
    98 T/A M6, 79 T/A 6.6L
    subscribed...
    and a blown gasket looks like this...(2nd clip, 71 mustang, can't remember which..there were two, same color, stripes etc, but one was said mach1, the other boss 351 don't get it)
    [ame]http://www.youtube.com/watch?v=mqD_6zyTX_k[/ame]
    a blown head gasket won't always show in the oil and water but normally will. Fact you have water seeping from around the plugs tells me it's either the gasket or cracked block. Just start tearing into it I guess. Sorry about your misfortune.
    Member dbrichrider33333's Avatar
    Hebron, IN
    Yellow
    2002 CETA
    Quote Originally Posted by goof4080 View Post
    subscribed...
    its cuz their both fords..lol
    Feb 2007
    California
    2000 Trans Am
    Ok well I started tearing into it yesterday and just an update, the front two plugs were wet with water....the rear two WERE NOT...(it's a four cylinder)..how exactly (besides tearing it all the way down) will I know if it a cracked block or just a gasket?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    well you pretty much have to tear it down and inspect the head gasket for signs of failure. If it looks ok, then you need to start looking for cracks
    Feb 2007
    California
    2000 Trans Am
    Ok cool....I thought that maybe since it was only in the first couple of cylinders that maybe was a sign that it was just the gasket......
    Once you get it off, make sure you check the head to ensure that it is flat. It's possible that it is warped and a new gasket will only be a temporary fix.
    Feb 2007
    California
    2000 Trans Am
    I'll take a look at that as well.....thanks for the suggestion!
    Pittsburgh
    2008 Hummer H3
    Wink
    Wont even last that long if it's warped...
    It would really be best to have the head checked for cracks, decked, and presure tested while you have it off, weigh the cost of a remanded head against the specialty work and go from there.. This is the only why to be sure you're not putting a damaged head back on the engine. I can tell you from some experiance (reason I hate I4's) that if the head has damage you can't see, you'll have the fun of doing it all over again.. I would also suggest (from orig op) a complete top-end gasket set. You may not need or use them all but you'll have everything you'll need too... Better than trying to piece some kind of set together guessing..
  1. Headgasket? Pleas help!
    By 01NavyBlueSLPSS in forum Internal Engine
    Last Post: 04-10-2011, 02:54 PM
  2. Oil on the floor, headgasket?
    By Johny Bee O in forum Internal Engine
    Last Post: 02-05-2009, 01:39 AM
  3. Blown G8
    By Sarge in forum GTO
    Last Post: 06-20-2008, 12:45 PM
  4. WTB blown up ls2
    By atiroc1 in forum Parts Wanted / Trade
    Last Post: 03-29-2008, 01:23 AM
  5. Blown LS1 (The bad kind of blown)
    By draxxus 2.1 in forum Firebird / WS6
    Last Post: 02-18-2008, 05:16 PM
