Thread: Change oil M5 gearbox
07-18-2010, 08:14 PM #1
hi,
I have a 2001 3.8V6 Camaro, with M5 manual gearbox.
the car has only run 37.300 km (23.000 miles), and the oil of the gearbox has never changed.
Do i need to change this fluid, and does the M5 gearbox has a filter like the automatic ?
07-18-2010, 10:55 PM #2
07-19-2010, 02:15 AM #3
thanks Smittro,
for your fast responce, what kind of oil do i need ?
is there a plug to let it out ?, and how do you check it, if there is enough fluid in the gearbox.
07-19-2010, 06:09 AM #4
No prob..
Manual trans lube should be checked every 15,000 miles or 12 months. Checking the level every other engine oil change wont hurt. The fill plug is located above the drain plug. They will be flat looking plugs (side of trans)and may have a couple of threads visible. Each plug will have either a square or hex shaped hole for you to get a large Alen key, or a 3/8 drive ratchet/breaker bar (without socket/extension) into for removal and tightening.. Full level is usually to the bottom edge of the upper plug hole. DON"T OVER TIGHTEN.. Fill till the fluid just starts to come back out of the upper hole, this indicates the case's full level.. The proper type of gear lube will be listed in your owners manual.. I can't think of it off hand as I have and auto
.. Just be sure the trans is as level as you can get it using jack stands or a lift to securely support your vehicle because it will take some force to break the plugs loose for the first time and helps ensure the full level is correct.. A small peice of rubber vacc line (about 10-12 inches long or so) attached to the "nipple" of the lube bottle will help make life a little easier when filling..
Gearbox solutions
By Fred in forum Automatic TransmissionReplies: 1Last Post: 05-09-2011, 06:00 AM -
Wanted: ls2 complete engine gearbox package
By doni d in forum Parts Wanted / TradeReplies: 2Last Post: 01-06-2011, 11:06 AM -
Help: 5.7 V8 Auto Gearbox, lost 3ed and 4th
By Vx SS in forum Automatic TransmissionReplies: 5Last Post: 07-20-2010, 03:58 PM -
What Gearbox
By transamgreen in forum DrivetrainReplies: 1Last Post: 01-21-2010, 06:59 AM -
sequential gearbox conversion
By grandkodiak in forum LT1Replies: 1Last Post: 07-24-2006, 01:49 AM
