Results 1 to 20 of 24
Thread: Pretty sick.
    Member EnjoiJoe's Avatar
    Weymouth MA.
    01 modded gtp
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    thats the stuff boners are made of
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Meh...I think the casing looks retarded...I'd rather have the traditional looking double hump twin screw look under my hood.
    Oct 2009
    pewter
    99 trans am
    clearance issues?
    Minnesota
    '10 ZR1
    How would that work with a LS7?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Wonder why it's only for the LS3. Are the head ports different on the LS3 than any other LSx?
    White Plains, NY
    2002 Trans AM
    that's what I am thinking. why not LS1?
    that would be awesome. it would clear the cowl clearence on the 4th gens
    odessa,texas
    69 hugger orange
    98 z28
    yes they are as a matter of fact
    White Plains, NY
    2002 Trans AM
    do LS3 heads fit LS1?
    odessa,texas
    69 hugger orange
    98 z28
    they will bolt on but they recommend you have a 4 inch bore at least with the bigger heads and you will have to have a ls3 style intake
    White Plains, NY
    2002 Trans AM
    Quote Originally Posted by dpinson View Post
    yeah but the LS9 SC will replace the intake
    odessa,texas
    69 hugger orange
    98 z28
    yes sir you are correct,lost track of why we were having the conversation in the first place
    if this would have been available earlier i might have tried it
    wouldve worked great on my motor
    White Plains, NY
    2002 Trans AM
    So the point is, that if I had a money tree growing in my back yard, I can get the SC and some nice Bored-out LS3 Heads, it would bolt right on?
    park bench
    gmcheviac
    rectangle ports, you'd have fun getting it to fit in your car aswell
    Member 05gtoautoX's Avatar
    riverton
    Impulse Blue
    2006 Pontiac G.T.O.
    Ya the LS3/L92 heads have larger valves too, the valves will not clear the bore, You will have piston wall to valve clearance issues, you must have a 4in bore or larger for these heads. MAST motorsports makes a small valve L92/LS3 head specifically for the LS1. But I believe you'll still have to run a L76/LS3 intake unless you're running a S/C.
    White Plains, NY
    2002 Trans AM
    Quote Originally Posted by 05gtoautoX View Post
    so a pair of heads $2000, and the LS9 SC around $7000?
    worth it? maybe not.
    odessa,texas
    69 hugger orange
    98 z28
    or you could run the l92 heads which are cheap
    but you would still need at least a 4" bore for the bigger valves to clear
    what would make it worth it is if that blower can put out as much as say my D1sc can but you would also be able to run the factory radiator and fans which become a big issue with forced induc. setups
    the roots style blower puts out almost turbo like torque with an easy bolt on setup (even easier than the procharger)
    bad side is the intercooler for those things usually suck and they put out a lot of heat
    odessa,texas
    69 hugger orange
    98 z28
    no you could however go get you an lq9 motor and bolt it right on
    but either way you still have all the bullshit that comes with a forced induc. car
    better fuel supply,drivetrain,tuning,and all the other little nickel and dime shit that adds up quick trust me
    Jan 2008
    DMV
    '00 A4 SS
    Don't get me wrong, it's pretty cool, but I agree with ls1camino, I'm not a fan of the casing at all. I would much rather have a twin screw in it's place.
    I'd also be curious as to how much this one would cost versus some of the more common kits that you see on the LS2's/LS3's such as Magnuson, Callaway etc.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    MAGGIE gets my vote.
  1. so sick of this.
    By bluefields88 in forum Camaro / SS
    Last Post: 08-07-2008, 12:35 PM
  2. got my Z06 and it's sick!!!!!!!!!!!!!
    By nomorefords in forum Corvette
    Last Post: 03-13-2008, 03:21 PM
  3. Sick!!!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 01-22-2007, 07:04 PM
  4. Anyone Seen This Movie??? Looks Pretty Hilarious in a Sick Way!
    By BillyT in forum Almost Anything Goes
    Last Post: 03-03-2006, 11:59 AM
