Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: LT Myth or not?
    Member Mike0202's Avatar
    Apr 2009
    LT Myth or not?
    Alot of people say their car "feels" slower after installing long tube headers. Is this a myth or do the LT's really loose a bit of torque down low but raise the power band?
    Indiana
    2009 Silverado Z71
    2003 Corvette MN6 Black
    Hell no, my car really woke up!.. but then again I had my mail order tune from Frost done at the same time.
    Member DaddysZ28's Avatar
    May 2010
    Westland, Michigan, United Sta
    2002 Camaro Z28
    I just installed a set of LT's and a true dual exhaust, haven't had my frost tune yet, but my car already pulls alot harder. Go get those LTs............have fun with the install on those too.....lol.
    Apr 2009
    Yeah I just come accross alot of threads where people are complaining of loosing torque.
    Manitoba
    blue
    1998 Trans Am ls1
    Quote Originally Posted by GoldenFlame View Post
    exactly! youll gain as much or more from the tune as the header swap, they work hand in hand. mpg increase , runs cooler, shifts better, all round better driver! Do the lt install and get it tuned. you wont regret it!!
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    I wish I could find the person who started this bs rumor and
    LTs are one of the best bang for your buck mods you can do to your car. Some civic driver probably told his v8 friends who didnt know dick about cars this in order to stop him from buying them and raping him even worse!
    Apr 2009
    Quote Originally Posted by BLK2KSS View Post
    hahah k cool. glad its not true.
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    it is posible to go with too big of a header and in that case you would loose some torque. for a stock to mild modified engine a 1 3/4 header would be best. anything more like a wild cam good flowing heads or bigger cubes i would probably run a 1 7/8 header.
    Myth
    NeW YoRk
    2001 ws6
    i have lts exhaust and cai.....370 rwtq.....i hope that answers ur question
    DFW
    '18 CTS-V
    '13 ZL1
    you lose some power down low but you make up for it in the mid to high end of the powerband.
    Coral Springs, Fl
    Sunset Orange Metalic
    My myth is your car sounds louder/meaner and you think it should be going faster than it is but in reality its faster than you started with
    Member Speed_kills_WS6's Avatar
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    I put longtubes on and it freed up some hp, made it sound better, throttle response improved, but really making it faster? Not really...
    Apr 2009
    Quote Originally Posted by Speed_kills_WS6 View Post
    What do you mean you ran the same times as before the LT's??
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    I bought the Texas speed 1 7/8 Headers and felt a good seat of the pants pick up. who cares about low bottom down torque i dont race down there. My mid range is fine and strong and top end is great.
    Manitoba
    blue
    1998 Trans Am ls1
    really? you freed up some hp but didnt make it faster? was is tuned with the header swap? i dont understand
    NeW YoRk
    2001 ws6
    this thread is full of lulz
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Wow.....
    You will gain power throughout the entire rpm range. argument ended.
    The only way that people might think otherwise is if they dont get their car tuned for it. After putting on LT's the car will not run the same as with manifolds. period.
    Most people end up running real rich on a stock tune with LT's.
    And I wish I could find it but at one point I saw 2 dyno graphs of before and after with the torque curve of the post install above that of the pre intstall across the entire range.
    Oh and you will pick up more power, or a higher amount of increase, in the higher rpm range than the lower. this can also contribute to some claims of losing power down low.
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    My 1/8th E.T. didn't change after long tube install. I did notice a 1 mph difference in speed. Tuning freed up 6 hp. My fastest time ever is still with the stock manifolds & street radials.
    Apr 2009
    hmmm thats strange
  1. tire myth
    By supercampeones4 in forum Wheels and Tires
    Last Post: 10-21-2009, 07:17 AM
  2. GM - Myth Busting the 3k OCI
    By CompSyn in forum Internal Engine
    Last Post: 07-26-2008, 05:17 AM
  3. GM - Myth Busting the 3k OCI
    Last Post: 07-24-2008, 11:52 AM
  4. HP myth????
    By lady_hot_rod in forum Firebird / WS6
    Last Post: 01-13-2007, 06:59 PM
