Results 1 to 18 of 18
Thread: Strut Tower Bar?
07-14-2010, 11:27 AM #1
Strut Tower Bar?
I bought a strut tower bar, just hasn't come in yet. I wanted to find out if there be be even a slight difference in handling. Anyone ever put one in?
07-14-2010, 11:32 AM #2
Id be suprised if you notice, with how much the fronts are enforeced anyway, i put one in mainly cause after my accident it bent my driver side shock tower up and over and i wanted extra strength after they bent it back!!
07-14-2010, 12:31 PM #3
Tightens up the front end a bit, Doesnt roll as bad when ya take a sharp turn, not a world of difference but you will feel a bit.
07-14-2010, 12:43 PM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Its a great place to rest your hand when you are working on the car.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
07-14-2010, 12:45 PM #5Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
People have different things to say. It work or don't
But I'll talk bout my experience
When I had my z28 and I wantd to do a burnout or something the dash board was shakin and the whole interior vibratin for some reaso.
I put the tower brace on the car
And all those vibrations were gone I noticed that long time after that
So I think that really helped the car00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
07-14-2010, 01:15 PM #6
I've seen people use it to hoist up an engine...that's about it
07-14-2010, 01:42 PM #7Life In The Fast Lane..!!
- Jul 2008
- SoCal, SD
Brickyard 400 Trac Car#10- 35th Camaro SS/LE Vert
It deff helps...there are just a lot of other mods that do more. It's a fine tuning peice.
07-14-2010, 02:02 PM #8
07-14-2010, 05:57 PM #9
07-15-2010, 06:45 AM #10
07-15-2010, 08:12 AM #11
great apperance mod for the engine bay
07-15-2010, 08:49 AM #12TerribleTed
- Jan 2010
- California-Sacramento-Roseville
Red- 2000 Chevy Camaro Z28
So my suspension mods,,
((So I installed one part at a time and then test drove mine...))
-shock Tower Brace installed-cornering felt tighter
-rear LCA installs...Car hoked up better when punching it and thats about all I felt at this point.
After Rear PHB install, car felt better around the turns-more predictble forces and all
Then I did front and rear sway bars and WOW,,,,that was the bomb. This mod alone should be done right off the bat first off.
My LCA's and PHB are poly/ball joint combos and yes this caused much more noise after installs. IF I had it to do all over again I would go with Ball joints on all, since its the best precision way of suspension but noisy too.
For the future...Shocks and Springs- Then Traction Control Bar...
Then maybe one day a total front end rework (Kmember, Upper and Lower A-Arms.
I could not believe how each little part played there role and would say to all that want to make there ride a better ride to install one part at a time to see the cause and effect of each. Also I recommend a bad ass poly mount for that transmission,,,that also was a cheap great mod all on its own.
07-16-2010, 06:41 AM #13
hey thanks for the tips, i willl be adding these to my list of mods!
07-16-2010, 10:31 AM #14
I'm installing everything all at the same time so I better feel a huge difference!!
07-19-2010, 10:49 PM #15
I noticed a slight difference but I notices it more after the BMR drop springs, UMI adj. Panhard/ LCA set, kyb agx's, and a Spohn sway bar set. I removed the bar when we dis the front struts since I was planning on changing the intake and never did so I reinstalled it and noticed a much bigger difference once the rest of the suspension was don't made it feel tight going though a 30mph turn at 60 plus it seemed stiffer and steering felt better. Maybe it was in my head or maybe it helped but for $80 it still looks great when you open the hood.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
07-21-2010, 06:39 PM #16
I have a bmr strut tower brace but I've always wondered if the fancy hotchkis one with the hinges was better or if their just both pointless gimmicks
07-21-2010, 07:52 PM #17Senior Member
- Jan 2010
- texas
silver- 2000 formula
mine is red.....and very pretty
07-21-2010, 08:19 PM #18Slow'er'Ass
- Thornton, CO
Does nothing.
Used mine to lift the car up....
Then removed it.
SLP Strut Tower Brace (93-02 V8, 98-02 SS)
By 5.0THIS in forum Parts For Sale / TradeReplies: 0Last Post: 04-23-2007, 02:48 PM -
Edelbrock Strut Tower Bar.
By Cerwin Vega Fan in forum Parts ReviewReplies: 5Last Post: 11-04-2006, 04:10 PM -
WTB Strut tower brace
By u69038 in forum Parts Wanted / TradeReplies: 1Last Post: 08-25-2006, 08:47 PM -
Strut Tower Bar
By WS6RedDragon in forum Suspension and HandlingReplies: 21Last Post: 11-22-2005, 12:06 PM
Or get one of the fancy ones.. You always need a spot for tools..lol
