Results 1 to 14 of 14
    Member xmarkx's Avatar
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    heater hose mod gone wrong???
    I did the hose mod and now the passenger side sits a half inch higher. after I got done I raised the car up under the axle to see how much clearance I had with the bump stops (I have sportlines). on the drivers side the axle is touching the bump stops but on the passenger side there's a half inch of space between the axle and the bump stop. I haven't adjusted my phb or my TA yet so I don't know if that could be it..
    if anyones got an answer let me know
    Senior Member
    texas
    2000 formula
    you put lowered springs on.....then lowered it more with the HH mod?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    more than likely you didn't seat the spring correctly.
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    I'll double check that.. I'm pretty sure that's not it tho.. I forgot to mention that I have the rear sway bar off right now. do you think that could be contributing as well?
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    Quote Originally Posted by sjsingle1 View Post
    yes....... after I put the springs in, the front was a little lower than the back, which is what I expected, but I want it to be completely level as well as low.
    Life In The Fast Lane..!! redracer1's Avatar
    SoCal, SD
    Brickyard 400 Trac Car#10
    35th Camaro SS/LE Vert
    Things to concider.
    Are the Sportlines new or used?? Did you pre measure, it may have already been off the 1/2", Stock shocks?? Could be the shocks also and may be worn out some.
    Sportlines sag after awhile each may even sag differently, if you're already sitting on the bump stops you're in for a bumpy ride. If the spacer is still in place on the bump stops I'd remove them.
    The phb is for side to side adj, the TA might not be much help either.
    Junior Member mcnoskyimages's Avatar
    Jun 2010
    DFW
    2002 Camaro Z28
    Jacking up on the differential does not guarantee the the care is being suspended level. maybe the jack was more to one side than the other. Personally, I would get some rubber on and let the car rest correctly before making a decision.
    Swap shocks to the opposite sides. That will tell you if you have a shock or a spring going down. The bad shock will be lower. If it doesn't change, you might have a spring go down.
    Shepherd, Michigan
    98' trans am
    if you are running stock shocks..you have my sincerest condolences
    Oct 2009
    Las Vegas
    2000 ss/1994 z28/1979 z28
    Thats way to low for me, but good luck!
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    they're brand new springs.
    I've got billstein shocks
    I can't put it on the ground right now because I'm in the process of istalling a new k member. I took the springs out today and put them back in to make sure they were seated right. I've got the car up on 4 Jack stands under the frame rails. my 3-1/4 ton Jack is busy holding up the motor right now and my pussy little 1 ton Jack doesn't go up high enough to fully load the suspension so I'm going to have to wait until I'm done with the k member to see what's up back there.
    Coral Springs, Fl
    Sunset Orange Metalic
    the back will get lower as time goes on :
    eibachs are notorious for it
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    I'm aware of that so I'm saving the stock spring spacer things (I can't remember their names)
    Coral Springs, Fl
    Just makin sure you're aware
    spring isolator btw
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    spring isolator btw
    damnit I thought that was it! lol
    also I plan on running 19s back there soon so I'll probably put the isolators back in at that time. right now I've got 275/40-17 so there's no wheel clearance problems at the moment. I don't know how I feel about the car riding on the bump stops though so I hope everything evens out when I put it back on the ground
  1. Question: heater hose??
    By one_sick_ss in forum General Help
    Last Post: 03-30-2011, 03:07 AM
  2. Question: heater hose bibs
    By homesimpsonr in forum External Engine
    Last Post: 09-17-2009, 07:57 AM
  3. 98 Z28 Heater Hose
    By dewayne1010 in forum General Help
    Last Post: 08-07-2009, 07:02 PM
  4. How to do heater hose mod?
    By Sweet Chops in forum Suspension and Handling
    Last Post: 08-21-2008, 06:22 AM
  5. Replies: 4
    Last Post: 12-23-2007, 05:53 PM
