    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    catch can install
    So i should have my catch can from ws6 store here on thursday, and i was wondering how people mounted them. The kit doesnt come with a bolt for the head, so what size bolt is needed for the head?
    Are you mounting it where the egr used to be (if you removed it)? If so, do you still have the bolts?
    Aug 2008
    peoria, az
    2001 WS6
    ive got an 01 so i dont have the egr. it would be on the front of the pass. side head
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Aug 2008
    peoria, az
    2001 WS6
    well I installed mine last night. It took me longer than expected because alot of installed pictures are misleading. In alot of pictures it has both tubes running to the throttle body/intake area are. One connecting to the piece on the intake and pcv valve, and the other somewhere underneath where the intake ant tb connect. In my case, i used the hose coming off of the pass valve cover, to run it to the top connection on the can, and then used the bottom connection to go to the pcv valve. Did i do it right? Also, how do you drain this thing? do you have to pull it all out including the hoses and drain it, or can you drain it somehow from underneath? although it doesnt look like there's anywhere for it to go
    Madison, WI
    2001 Silverado Z71
    I believe your can is hooked up correctly. Hard to tell from the pic, it kinda dark.
    I installed the LS6 PCV valley cover, that why mine goes under the intake.
    2002 Z28
    What size Bolt?
    Sooo.... what size did the bolt wind up being in the head?
  1. AMW catch can install .....in pics
    By sjsingle1 in forum External Engine
    Last Post: 07-06-2012, 07:17 AM
  2. Question: oil catch can???
    By reaper ws6 in forum General Help
    Last Post: 08-26-2011, 09:36 AM
  3. C6 Corvette Catch Can - Catch Me If You Can
    By Ed Blown Vert in forum Corvette
    Last Post: 07-29-2009, 02:00 AM
  4. Catch can install ? Let me know if this is right
    By brian r in forum General Help
    Last Post: 07-16-2009, 11:28 AM
  5. catch can install question
    By mvvette97 in forum External Engine
    Last Post: 09-15-2006, 09:56 AM
