Results 1 to 11 of 11
    Guitar God
    Plano
    2002 Vette
    C5 died while driving...won't start.
    So, my '02 C5 all stock just died while driving around 60mph. All guages were fine, oil pressure, temp, etc. Oil level was ok. Tried to start and it wouldn't unless giving it alot of throttle. Then it would only run for a few seconds on what sounded like 1 or 2 cylinders.
    On a side note, I think it died at the same time I set the cruise control. Could this have caused this?
    I haven't checked any fuses yet, just had the car towed. Real weird...
    Coral Springs, Fl
    Sunset Orange Metalic
    Sounds like an ignition problem to me
    I'm in to see what others have to say
    Guitar God
    Plano
    2002 Vette
    Kinda what I thought, just weird that it's been running well and just quit all together...
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Did you check the fuel pressure?
    Coral Springs, Fl
    I would try cleaning your MAF. Do you use an oiled filter? Wouldn't think this would cause a problem that big but it's worth a shot.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Quote Originally Posted by importhater81 View Post
    ^This.
    Junior Member MNGTO's Avatar
    Minneapolis, MN
    2004 GTO
    I agree with checking fuel pressure. Kinda sounds like a possible fuel pump failure.
    Corvette Moderator BlownC5's Avatar
    Essexville
    Jet Stream Blue
    2009 Lingenfelter ZR1
    any dtc codes?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by BlownC5 View Post
    any dtc codes?
    and with others..sounds like a fueling issue. I'd check fuses also and connections ..make sure the two connectors going to the pcm are good and tight.
    tell us more about before this happened..rain ? anything odd happen? has it done anything like this before ?
    the more info you can give us the better.
    Guitar God
    Plano
    2002 Vette
    Ok, so the dealer just got back to me. They said that the Cat Converters are clogged??? Wierd. It wasn't having any performance issues, only 69K miles. I can't really believe that the cat's are bad already.
    Guitar God
    Plano
    2002 Vette
    Ok, so here's the emissions warranty...
    http://www.epa.gov/oms/consumer/warr95fs.txt
    I guess I'm going up there in the morning and throw a fit before dropping $2,000 on a new Cat... It shouldn't be clogged at 69k miles no matter what...
    I just would think the car would have a check engine light on or something before just dieing and won't start. Maybe it would even idle rough or something???
  1. Help: My ss died.
    By 98maro in forum General Help
    Last Post: 12-24-2010, 08:52 AM
  2. 02 Z just died and no start HELP!
    By Limited87 in forum General Help
    Last Post: 04-29-2009, 12:55 PM
  3. Car died while driving...now won't start...
    By JHN in forum General Help
    Last Post: 07-14-2007, 09:36 PM
  4. Cold Start/Warm Start Problem
    By I'mLS1John in forum General Help
    Last Post: 02-23-2007, 07:11 PM
  5. Cold Start/Warm Start Problem
    By I'mLS1John in forum New Member Introductions
    Last Post: 02-22-2007, 05:26 PM
