Thread: launching
    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    launching
    I'm trying to improve my launch. I've got 340 to the wheels, and street tires on my m6. What's a good rpm to launch at with an c5 z06 clutch? my tires are continental conti extreme contacts. What are some good launching methods? feathering? dropping?
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by Ramairgod84 View Post
    One thing i've leaned is not to drop it. Not sure exactly what RPM to start at because that usually depends on the tires and conditions. I wouldn't start too high and after takeoff slip the clutch a little while slowly getting into the throttle. All i know to say
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Agree with tater. I would start at around 2K. I found that when I was stock running stock tires my best launch was around 2500RPM and feathering out the clutch. You can basically go to the track and start off low and just keep raising it each pass to see what works best for your current set-up.
    What I do know is you won't be able to drop the clutch. You can't even do that with DR's.
    What is your current 60' time?
    crazy ass white boy dennis ss's Avatar
    Mar 2010
    melbourne florida
    navy blue metallic
    2002 camaro ss
    Feathering seems to work the best. I run at orlando speed world and the track is sticky as hell. I can drop the clutch at almost 3,000rpm's and end up bogging on street tires
    2002 Camaro SS/M6. Volant CAI, 80mm TB w/spacer, cat delete w/ ory, borla XR-1 w/ cme, custom tune, 3.73's, 8,000k HID headlights and foglights, 19" staggered ruff 278 wheels.
    Member IH8EVRY1's Avatar
    Apr 2010
    Savannah, GA
    I wish I could've launched at 3K in my M6. About 2K was all I could get and dump the clutch and get any kind of traction.
    Aug 2008
    peoria, az
    2001 WS6
    ive tried dumping it a few times and i just bog or spin. i tried feathering it around 2500 yesterday and did...ok... but would 2000 be better
    Your engine does not have enough power at lower RPMs to just dump the clutch. This is why you bog.
    Just do what I suggested. Start at a lower RPM and work your way up. Get your track slips and see which launch gives you the best 60'
    Aug 2008
    peoria, az
    2001 WS6
    will do
    Senior Member
    Mar 2009
    Milwaukee
    Arctic White, red/gray
    1997 Corvette, 92 Typhoon
    I usually started around 2800-3k and slip the clutch on street tires, the rpms usually get down to the mid 2ks let the clutch pedal out while rolling on the throttle. I got into the 1.9s 60ft with my street tires a couple of times with this method. My chart at that time said 35X to the wheels.
  1. What RPM are you launching at?
    By 97ramair in forum Drag Racing
    Last Post: 05-23-2010, 10:53 AM
  2. Launching on ice???
    By Hot Black Trans-Am in forum Drag Racing
    Last Post: 06-23-2008, 01:38 PM
  3. Launching
    By GNICTRY in forum Drag Racing
    Last Post: 02-18-2008, 06:24 PM
  4. Launching a m6
    By hutch1999 in forum Drag Racing
    Last Post: 10-24-2007, 05:22 PM
  5. Launching
    By Havoc_S in forum Firebird / WS6
    Last Post: 10-03-2005, 03:32 PM
