Results 1 to 11 of 11
Thread: compression calculator
07-02-2010, 04:18 PM #1
can heads be milled slightly and not have intake sealing problems? just different pushrod length?is .020 too much?
07-06-2010, 02:22 AM #2
.020" mill will be fine...I milled .040" off of mine
07-07-2010, 04:11 PM #3
actually the heads i'm looking at have.055 milled. seems like quite a bit
07-07-2010, 06:21 PM #4
What heads are they? I've seen them milled over .060" before, but that is alot
07-08-2010, 05:58 AM #5Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I see flycutting in your future if you're getting a cam as well.
07-08-2010, 07:16 AM #6
07-08-2010, 03:03 PM #7
07-08-2010, 03:18 PM #8
ok here is the problem. this is my first gen 3. On the advice of a friend when i ordered my block and rotating assy. I got -9cc dished pistons to stay around 11:1, 11.5:1. some compression calculators put me at 10:1 and some at 12:1. Before I shell out more cash I want to make sure of what I'm doing before i do it. The car is a DD. So this is what Ive got ....
3.905 bore
4.00 stroke
-9cc pistons
6.125" rods
07-08-2010, 05:35 PM #9
Do you know how many cc's the heads are now?
60cc heads I get 11.06:1
58cc I get 11.33
Try wallaceracingcalculators
07-09-2010, 02:46 AM #10
[QUOTE=mark21742;2380858]Do you know how many cc's the heads are now?
60cc was planning on going with gmpp 88958622. wish i had done more research before ordering those -9cc
07-09-2010, 04:14 AM #11King 0f n00bz
- Jan 2006
- Shepherd, Michigan
flycutting is taking some material off the top of the piston to increase PTV.
Compression Calculator!!!
By My00Z28 in forum Internal EngineReplies: 6Last Post: 12-25-2011, 01:22 PM -
Gear/MPH Calculator
By Y2KPewterSS in forum DrivetrainReplies: 1Last Post: 04-28-2010, 06:07 PM -
D/A calculator....
By 0rion in forum Drag RacingReplies: 19Last Post: 10-07-2009, 05:51 AM -
Horsepower Calculator!
By aquickbird in forum External EngineReplies: 4Last Post: 12-25-2007, 05:12 AM -
Drag calculator!
By ramrod in forum Drag RacingReplies: 6Last Post: 05-27-2007, 03:03 PM
