Thread: Temps High. Cooler Position
06-30-2010, 03:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I think I finally figured out why my Tranny Temps were so high.
Only 1/4 of my cooler was being used.
I have my B&M 24k cooler mounted in front of the condenser with both hoses pointed down.
The top 3/4 of the cooler is cool so I know fluid isn't flowing. So is it because its clogged or air??
07-02-2010, 12:11 PM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Changing out the external cooler didn't help.
76 outside. Engine temps 190. Tranny temps 216. Sitting at idle for 15 minutes dropped it one degree.
Even on the freeway it never dropped.
Going to bypass the radiator cooler.
07-02-2010, 02:41 PM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Looks like bypassing the radiator cooler helped. Not sure if it was clogged or what.
But engine temps were 195-200. Tranny temps never went over 199 on the freeway.
City speeds tranny temps went up to 205. But after a short idle they dropped to 199.
The cooler was completely hot all over. So flow must have been an issue.
I'll go for a longer drive next time.
07-02-2010, 02:59 PM #4
Seems like it would push the air out of there, but who knows. Anything in the instructions as to how it should be mounted? I have a suction gun that I use to push fresh fluid through the cooler. Just did it on a friend's Dart when we swapped out his transmission. It works great.
07-02-2010, 03:12 PM #5Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I don't think air was the issue. Nothing in the instructions about position.
07-02-2010, 04:56 PM #6Senior Member
- Jan 2010
- texas
silver- 2000 formula
one of the reasons i switched to a 160 stat was to keep the tranny cooler
P0343 DTC P0343 Camshaft Position (CMP) Sensor Circuit High
By Camaro98Z/28 in forum General HelpReplies: 11Last Post: 10-16-2013, 07:57 AM -
Stalling at Hwy Speeds and High Temps
By Shudson105 in forum LT1Replies: 3Last Post: 10-08-2010, 10:51 AM -
Help: High temps = pinging
By 02fbody35th in forum General HelpReplies: 8Last Post: 05-24-2010, 06:46 PM -
Fan temps? 160? 195? help please..
By Z28LS1 in forum External EngineReplies: 8Last Post: 06-03-2007, 08:19 PM -
PO343 Cam Position Sensor Voltage High.
By 24v in forum Computer & TuningReplies: 0Last Post: 02-14-2007, 04:34 AM
