Thread: No start / spin issue
06-27-2010, 06:53 PM #1Junior Member
- Dec 2006
- Alabama
Black- 2002 Trans Am
Have a 2000 WS-6 Formula with an electrical issue. A while back, the car was sitting in the garage and was making a chattering noise like a relay opening and closing. By the time I caught it, the battery was nearly dead so I took off the negative cable and charged the battery. After I got it fully charged, I put the cable back on, cranked the car and thought everything was fine. Since then, I haven't been able to get the car to even spin. I turn the key and all the lights come on like normal, the fuel pump runs but that is all. I have replaced the starter relay and that didn't help. Also, I am not showing any security codes like VATs. Any suggestions would be appreciated. This thing is running me nuts.
06-27-2010, 06:59 PM #2Senior Member
- Apr 2008
- Madison, WI
You may need to tighten the battery cables up a little bit. first go up and grab a hold of the cables at the battery. If you can rotate them on the battery post at all, the the cable is loose and needs to be tightened. Seen it a million times on side post batteries
06-27-2010, 08:39 PM #3Junior Member
- Dec 2006
- Alabama
Thanks for the idea but the cables and connections seem to be fine all the way to the starter. One of the main things I have wondered about is what was chattering? The key was not even in the switch and I never found anything left on. I'm beginning to wonder if this thing is posessed.
06-27-2010, 09:34 PM #4
Possibly a power lock relay issue imho..
06-28-2010, 02:53 AM #5
06-29-2010, 03:54 PM #6
Check your fuses and realys for burn out, sounds like tehre may have been a short some where, lookk for any rodent damage or corrsion around the fuse block under the hood and check any connections you can get to under the dash.
Help: 1998 Camaro LS1 No start issue....Looking for help
By 510SS in forum General HelpReplies: 3Last Post: 12-10-2013, 09:35 PM -
My mystery no start issue is back!
By HOBS in forum General HelpReplies: 10Last Post: 08-27-2011, 08:45 AM -
Help: My T/A wont start, security issue!
By sdoyleT/A in forum General HelpReplies: 30Last Post: 02-27-2011, 05:48 PM -
Start up Issue
By 98formy in forum Computer & TuningReplies: 11Last Post: 03-18-2008, 01:23 PM -
All about Spin
By CaptainCaveMan in forum Political / Debate ForumReplies: 0Last Post: 01-22-2008, 12:46 AM
