Results 1 to 20 of 25
    Senior Member
    Detroit
    Black/Red/Black/Red
    98WS6/06MCSS/86GN/06H3
    Question My friend is going to buy a lt-1 T/A tommorow,any advice?
    I'm going with him to check out the car, It's a 1996 T/A white with 96k, I hear the opti spark is a bitch on the lt-1's, I'm mostly a ford guy, so I dont really know much about the F-bod's so any advice would be appreciated.
    Member whoa guy's Avatar
    Dec 2003
    Charlotte, NC
    92 K Blazer/'03 H-D Deuce
    '96 are the best year for lt1. Only differences really from prior years are dual cats. my opti in my '95 never went bad until after i sold it with 155k on it. '95 + 96 had the vented opti. Most of the intakes will leak sooner or later.. a car with 96k has probably been fixed. Find out when the plugs were replaced as they are the biggest pain in the ass to replace. Other than that, they are good cars.
    I had a pretty good lt-1 car. Never had a major problem, and found the motor to be quite reliable. My old one had a best 1/4 time of 13.7, and that was with around 125k mi on just an catback and 3.73 gears. If its an auto, I recommend getting shorter gears, and getting a higher stall converter... throw on a catback and gut the cat.. car will sounds brutal! lt-4 heads and cam are a common swap.
    1 of 396 T/A Conv 2001 Wayah-bird's Avatar
    Feb 2006
    North Carolina
    Taupe/Red
    2001 Trans Am Conv
    Better be cheap!
    A T/A with 96K better be a cheap price. I owned a '96 Formula for 9 years and put 40,000 on it. It was perfect all those years but things were starting to go. Not the engine or tranny, but everything else due to age. I can't imagine the repairs needed if I put 96K on it or if the car was run real hard all of those miles. Make sure you know who the owner(s) were and if a bunch of kids owned it, don't even think about it unless your friend wants to build up from scratch. A 10 year old performance car is TROUBLE unless you know who the owners were and how they cared for the car. Good luck!
    Member Since Aug 2000 LS1 Eddie's Avatar
    Wilkes-Barre PA
    It should be somewhat low priced depending on the condition and maintence. My car has 96 on it and I sure wouldn't let it fo for something like 6k. But I'm not selling it anyways. Some may argue that the 95's are the best year because they still came with OBD-1, single cats, and the vented opti. IMO it is the best year but I might be a little biased. Opti sparks aren't any fun I will agree, but the LT1 is a proven performer and a real under-dog that will shock you if modded up the right way!
    1995 Camaro Z-28
    Black/Neutral|A4 GU5
    Modifications:
    Borla, MAC Mid's, SLP Level 1 Suspension with Prokit, SLP STB, SLP CAI, 1LE Elbow,Phillips HID, Advanced Induction 180cc Heads/224 Cam,Built 355, Yank 3200
    Senior Member
    Detroit
    Black/Red/Black/Red
    Well he only wants 5k for the car and it seems to be in really good shape from the pics, it was owned by a single older man so yeah ill make sure documents and all are presented, if everything checks out.
    Feb 2006
    North Carolina
    Taupe/Red
    2001 Trans Am Conv
    Sounds OK so far
    Well that sounds encouraging if it checks out. Again, good luck!
    advice: buy a mustang instead
    San Diego
    I used to have a 96 lt1. I had nothing but problems with mine. The engine and tranny were fine. I bought mine when it was 2 years old and it had 35k miles on it (I finally sold it when it had about 70k miles on it). I had to fix something about every 2-3 months. I had to fix the power windows a total of 5 times, water pump, fuel pump, window regulator and motors on both windows, 3 o2 sensors, and countless other things. The motor and tranny seem to be pretty good....everything else on the car will nickle and dime you to death. If the rest of the car was built like the engine and tranny it'd be a very good car....I'd never buy another lt1 again though.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    My 97 was at 178,000 when I sold it not long ago, they aren't as bad as you will hear if it is maintained. Clutch didn't go until 160,000 and opti went at 174,000. The opti won't be as bad as you hear either, it's just non-conventional to have to pull the water pump for a distributor change. The most important thing is WHEN it has to be changed ensure a good clean water pump install to prevent leaking, and the biggest opti killer should not be overlooked -bleeding the cooling system, those bleeders will send all of the water right down on the opti so cover the opti when bleeding the system. Oh yeah, 97 was the first year for dual cats not 96 and it resulted in the power rating going up to 285 from 275, not important though just thought I'd throw it in there. After that car I was in love with the LT1 and had a lot of trouble convincing myself to get an LS1.
    Dec 2003
    Charlotte, NC
    '96 CA emissions cars saw the dual cats.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by whoa guy
    odd, got a link to something about that?
    Dec 2003
    Charlotte, NC
    Quote Originally Posted by z_driver1
    http://www.camarosource.ca/php/camar....php?year=1996
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Wow, I shall now call you daddy
    230,55,147 91Z28's Avatar
    Houston
    Cyclone Grey Metallic
    2006 GTO
    LT1s are reliable as hell, I didn't have an Fbody but I had a Caprice 9C1 (police car) with an LT1 with 155k miles on it. I drove it up to 240k miles and only replaced a power steering hose.
    Oct 2001
    Colorado
    95 Z28
    Actually.. it was 1995 when all automatic equipped LT1 cars sold in California got dual cats.
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    My advice, buy an LS1
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by 5.0THIS
    according to wikipedia (so who knows) 93 was when cali started getting them, then 96 for all of em?
    San Diego
    96 cars had 285 hp.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    so what years had what? how long did cali have dual cats? and does that mean that for all those years cali cars had 285 considering dual cats is what upped it from 275? All this time I had no idea. . .
    Fresno,ca
    Dude lt-1s r cool but compared o an ls1 stock for stock and even a stock ls1 and semi modded lt-1 the ls1 is still gonna kick its ass so juss tell your buddy to get an ls1.
  1. So I'm checking out an SS tommorow...
    By rajiv1998 in forum Camaro / SS
    Last Post: 06-30-2010, 05:50 PM
  2. advice on handling a friend issue
    By RealLiveMD in forum Almost Anything Goes
    Last Post: 10-03-2008, 12:22 AM
  3. ugggh I have to get up at 8am tommorow
    By 310stanger in forum Almost Anything Goes
    Last Post: 11-22-2007, 05:42 AM
  4. NASCAR Car of Tommorow
    By snaggeltooth in forum Almost Anything Goes
    Last Post: 04-03-2007, 02:51 AM
  5. Anyone racing at the Q tommorow
    By JD_Z28 in forum Western Members
    Last Post: 09-16-2006, 11:15 AM
