Results 1 to 13 of 13
Thread: Running hot
06-25-2010, 03:55 PM #1
Running hot
My car is runnin hot after a lap around town smokin a cig my temp gauge is already at 210. I have a 165 degree thermostat just put in less than 6 months ago and flushed the radiator last month but thats not helpin for some reason so any ideas or suggestions? thanks
06-25-2010, 04:06 PM #2crazy ass white boy
- Mar 2010
- melbourne florida
navy blue metallic- 2002 camaro ss
2002 Camaro SS/M6. Volant CAI, 80mm TB w/spacer, cat delete w/ ory, borla XR-1 w/ cme, custom tune, 3.73's, 8,000k HID headlights and foglights, 19" staggered ruff 278 wheels.
06-25-2010, 05:42 PM #3
06-25-2010, 05:45 PM #4
First, don't hold your breath on the stock guage being completely accurate.. Second, 210 is normal with a stock thermo.. Do you have a SES light on?
06-25-2010, 05:45 PM #5
06-28-2010, 03:03 PM #6
i have an aftermarket stat its a 165 and the car feels like its puttin off as much heat as its readin, and ya my SES did turn and its readin transmission componet slipping ive cleared the code twice and its on again it comes on when the car gets really hot causeing the tranny to get hot, and yes my fans work.
06-28-2010, 05:24 PM #7
What's the outside temp? Has your car been tuned to allow the fans to turn on sooner to work with your 160 thermostat? Maybe check to make sure your water pump is properly circulating your fluids..
06-28-2010, 06:52 PM #8
low to mid 90's and no tune...
06-28-2010, 09:32 PM #9
If the fans aren't set to turn on with the lower stat it's pretty useless. My car never passes 180 or so on a hot day with my 160 and my fans set to match.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
06-29-2010, 09:50 AM #10
06-30-2010, 03:22 AM #11
Stat without the fans set will do nothing for you. My 5.0 has a low tem stat buy belt friven fan so no tuning needed. Fbody cars have electric need the fanss set to whatever tem the stat is
06-30-2010, 10:51 AM #12
Hook your car to a scanner, it will tell you the temp the computer is seeing.
06-30-2010, 02:41 PM #13
I agree with what the others are sayin, probably need to get your fan set to the stat, but here's another thought. Maybe the thermostat is bad. The reason I say this is that I noticed you said 6mo ago you bought the thermostat, then last month you did a radiator flush. A couple years back I had bought a thermostat, then a few months down the road I had my radiator flushed, well a few days later I noticed the temp hand was settin a little high and my car was making a funny noise (I know you didn't mention anything about your car making a noise though) well it turned out the thermostat was bad. I don't know if the engine flush had anything to do with that or not, but now when I do a flush, the thermostat also gets replaced. Just a thought
Running rough if running at all help
By ichliebecamaro in forum LT1Replies: 3Last Post: 01-25-2010, 10:54 AM -
Car is Running
By Ed Blown Vert in forum Almost Anything GoesReplies: 106Last Post: 11-11-2009, 01:21 PM -
Question: running 12`s
By SSMOKEshow in forum Drag RacingReplies: 41Last Post: 03-15-2008, 05:42 AM -
Got The Car Running Again But
By theslow00 in forum Western MembersReplies: 8Last Post: 03-05-2008, 12:08 PM -
Need help, car not running right?
By blackSS01 in forum General HelpReplies: 5Last Post: 10-15-2006, 08:20 AM
beat me to it..
