    Member km346's Avatar
    Nov 2008
    masssaaechuuuseettes
    1998 hardtop SS
    Question about coolant temps
    Hey all,
    I recently took my SS for a ride with the scan tool plugged in. I realized that my coolant temps where sitting at 200-205 while at cruising speed. Is that normal for a stock thermostat in our cars? Just wondering.... seemed kinda high to me, what do you guys think?
    Thanks
    -Kyle
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    perfectly normal. hot coolant temp is like 235 to 240ish. Overheating is 250 to 260ish
    Nov 2008
    1998 hardtop SS
    Thanks for the response Cutlass... I know our stock T-stat is 195 degrees but for some reason i thought that was kinda high. I plugged the tool into my truck which has a 195 T-stat and that seemed to run around 187-190. I guess the large grille and fan clutch setup on the truck is making all the difference. On a side note I noticed my FTRA set up is keeping IAT temps very close to ambient air temp which is good.
    Senior Member
    texas
    2000 formula
    i thought stock stat was 180 ?
    Stock thermostat is 195-198 degrees with the fans set at something like 212 and 224 degrees. With our 180 degree thermostat and reprogrammed fans I finally saw a high of 205 on the scanner idling in traffic this weekend on a 90 plus degree day with the AC on. Usually runs 185 to 194 for the most part.
    Next... MrKid's Avatar
    Sep 2009
    Milford, CT
    '68 Camaro RS, '11 Camaro
    Yeah it seems 15 - 20 degrees over t stat number seems norm I guess. My 160 seems to run about 185 in high heat w/no AC.
    keep in mind that the t-stat rating is just where it opens....the fans control the temps after that.
  1. Help: with coolant question!
    By clg82 in forum Firebird / WS6
    Last Post: 08-19-2015, 12:57 PM
  2. Evans Coolant question
    By johngoodman in forum External Engine
    Last Post: 03-06-2010, 11:00 PM
  3. Question, temp gauge, running temps.
    By hozeman in forum Camaro / SS
    Last Post: 07-27-2008, 01:20 PM
  4. Fuel and coolant question. PLEASE help.
    By TransAmcoupe98 in forum External Engine
    Last Post: 10-08-2007, 07:50 PM
  5. Coolant question
    By burnout in forum General Help
    Last Post: 11-09-2006, 12:54 PM
