Results 1 to 3 of 3
Thread: looking for a 4l60e core
06-24-2010, 04:33 PM #1
looking for a core to do a build on, the question is what 4l60e cores would work, does it have to 4th gen specific ? done alot of searching and havent found the info i'm looking for, just wondering incase i came across something i could use, thanks for any help
06-24-2010, 09:03 PM #2
If your an LS1 then I think it would need to be an ls1 core unless you plan on changing to bigger input shaft, 5 pinion plants and a different drum then it is a moog point and all you need is a case to build on. If your not going bullet proof then you need the correct input shaft so I think any ls1 Fbody and maybe a GTO case might work. Is yours a 2 peice case or 3 peice case?
06-24-2010, 10:05 PM #3
didnt know they came with a 3 piece case too ? but it's looking like i might have found an f-body case, i'm going to be taking the next few months to do this, looking at superior/fairbanks serovs, 13 vane pump, red eagle bands and clutches, hardened input shaft drum assembly, hardened reaction shell and bearing, 3000 stall... that's about what i got lined up right now.... need to set down with my buddy to figure out the rest..
radiator core support
By joejenkinsglass in forum Parts Wanted / TradeReplies: 2Last Post: 06-14-2009, 08:20 AM -
Heater core bypass
By hix5000 in forum General HelpReplies: 6Last Post: 07-14-2008, 04:42 PM -
Looking for LS1 T56 or Core
By hosspowerinc in forum Parts Wanted / TradeReplies: 9Last Post: 02-06-2008, 09:40 AM -
'99 Heater core replacement
By jad628 in forum General HelpReplies: 3Last Post: 11-08-2006, 05:54 PM -
'95 4L60E vs '01 4L60E biggest difference?
By kgrantkey in forum Automatic TransmissionReplies: 9Last Post: 04-28-2006, 01:09 AM
