    Jun 2010
    Baltimore Maryland
    Burgandy
    2000 Pontiac Trans Am
    Ruff racing rims help
    Just bought a 2000 Trans Am and was looking at some Ruff Racing 287's will these fit? with little or no problems?
    Manufacturer: Ruff Racing
    Size: 18x8.5(front), 18x9.5(rear)
    Offset: 20mm on all wheels
    Material: Aluminum Alloy
    Finish: Powder Coated Black Center with Chrome Lip
    Bolt pattern: 5 X 114.3 mm
    rims are for sale need help fast so someone else doesn't get them first
    Member vikingramair's Avatar
    Sweden
    BLACK
    1999 Trans Am WS-6
    Think you should have 5x120,65 bolt pattern.
    Steph my1stss's Avatar
    May 2010
    NJ
    2001 camaro ss #4168
    Just bought rims, you definately need 5x120
    Jun 2010
    Baltimore Maryland
    Burgandy
    I have seen many trans am's with this wheel on it. I was trying to get the rims with tires cheap off ebay. Do they sell the ruff racing rim in a 5x120 bolt pattern.
    http://img157.imageshack.us/f/img0517fc2.jpg/
    Is this rim I found just wrong. It does say they were pulled off of a mustang? Should I be searching for the same rim with different bolt pattern? does it exist?
    Jun 2010
    Baltimore Maryland
    Burgandy
    I found these and these are the size I want! right
    RIM BRAND: Ruff Racing
    MANUFACTURER PART NUMBER: 9308912B45
    RIM SIZE: 18
    RIM WIDTH: 8.5 Front/ 9.5 Rear
    NUMBER OF BOLTS: 5
    BOLT PATTERN: 5x114.3, 5x120
    OFFSET: 38 Front/45 rear
    RIM MATERIAL: Alloy
    RIM STRUCTURE: 1 Piece
    FINISH: Black
    Member xmarkx's Avatar
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    Quote Originally Posted by bouttime View Post
    I could be way off here but I don't think mustang wheels are interchangeable with f bodies..............
    Jun 2010
    Baltimore Maryland
    Burgandy
    that's what I thought. But the difference is the first set I am looking at from the mustang are 5x114.3mm and 20' offset, while the new ones I found are 5x114.3/5x120 with a 35' front and 45' rear offset which is what everyone in the pictures I have seen have. So I'm guessing I should be buying the ones with the 35 and 45 offset
    May 2010
    NJ
    This site should tell you everything you need to know, this is where i ordered my 20's i got them real cheap maybe they will be cheaper than ebay $1400.00 mount, balanced, delivered to my door with Nexen Z rated tires. Check it out www.hubcap-tire-wheel.com
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    5x120 is the way to go. Anything even close to that number and you're looking at stretched/snapped studs after install. The F-Bodies and GTOs use the same bolt pattern. I think C5s and up use the same pattern as well. Just backspacing is different. I could be wrong tho.
  1. Oe deep dish 18's or 18" Ruff racing rims? Help!
    By bouttime in forum Wheels and Tires
    Last Post: 07-19-2010, 05:10 AM
  2. Ruff Racing 278s
    By 2001camaroSS in forum Wheels and Tires
    Last Post: 02-11-2010, 07:42 AM
  3. For Sale: parting out 99 ws6, brand new ruff racing rims.
    By 1fastcamarosss11 in forum Parts For Sale / Trade
    Last Post: 12-15-2009, 10:26 AM
  4. Question: Ruff Racing hyperblack rims
    By krug07 in forum Wheels and Tires
    Last Post: 03-24-2008, 12:29 AM
