Results 1 to 3 of 3
Thread: air pump
    May 2010
    wellsville missouri
    1996 trans am ws6
    air pump
    ok my check engine light is on and the code said it was a sencondary air injection relay and valve malfunction so checked the fuse on the air pump and it was blown put a new fuse in and blew it to what should i do? anyone had this problem before?
    what are the actual code numbers? If you're popping fuses I'd start by looking for shorts or bad connectors. Could possibly be a bad pump but start simple. If you know someone that does inspections and will pass you then just take it off.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Here's a good writeup on removal - http://www.ls1.com/forums/showthread...=secondary+air
  1. Oil pump ?
    By Mich's04 in forum GTO
    Last Post: 10-13-2008, 07:39 PM
  2. air pump
    By binnie2424 in forum Camaro / SS
    Last Post: 09-15-2008, 07:44 PM
  3. Power Steering pump leak?! new pump or seal kit?
    By JehalinTA in forum General Help
    Last Post: 03-18-2008, 11:05 PM
  4. air pump Q
    By pipes_ta in forum Firebird / WS6
    Last Post: 10-14-2006, 08:25 PM
  5. Fuel Pump Pump Problem?????? Help!
    By undertakersT/A in forum General Help
    Last Post: 04-24-2006, 10:55 AM
