06-15-2010, 05:28 AM #1
PTV issues with small cam /mild setup??
I just installed a 04 ls1 short block and PRC 2.5 5.3 heads (unmilled) I am using 7.4 pr's and ls7 lifters (which superseded all gen3 lifter part #'s) along with some 1:7 Scorpion rockers..and a tiny cam 208/212 .525/.532 114lsa..
-now the weird part..
We torqued/set preload on one side (all 8) and went to turn the motor 180* to torque the other...and the valve was hitting the piston (99% sure)..wtf..I purposely kept this setup mild so shit like this would not happen! I am using stock head gasket btw..
-I am going to check pr length today, but come on...hittying the piston with a near stock size cam
-ANY thoughts or comments are welcomed!! I am kind of puzzled
Thought I would start getting a little more active on here
06-15-2010, 05:52 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
did you measure for correct length on the pushrod before all this or did you kind of just guess ?
06-15-2010, 01:08 PM #3
Nothing was changed from oem spec..stock pistons,heads unmilled,stock basecircle on cam,RR's utilize stock length pr's...So I talked to a few big name sponsors and they said 7.4 would be fine ....I think I may be a tooth or 2 off on my chain...I will let you guys know.....
06-17-2010, 06:17 AM #4
A little update...I think the problem is the slp timing chain..It may be 1 tooth off or out of adjustment..I will let you guys know
06-18-2010, 06:50 PM #5
yeah, something is up there. No way that should be hitting. Measure your pushrods too and make sure you got the right rods.
Any issues running FI setup NA?
By Snowboardr18 in forum Forced InductionReplies: 3Last Post: 03-19-2010, 03:40 PM -
small NOS setup possibly FS
By EVL LS1 in forum Parts For Sale / TradeReplies: 1Last Post: 11-09-2007, 01:20 PM -
Looking for small turbo setup
By TransAmcoupe98 in forum Forced InductionReplies: 6Last Post: 07-17-2007, 04:05 AM -
looking for a mild cam
By 00maroz28 in forum Internal EngineReplies: 15Last Post: 06-18-2007, 07:08 PM -
Nitrous setup for a mild Build
By lrader99 in forum NitrousReplies: 7Last Post: 03-01-2007, 03:58 PM
