Results 1 to 20 of 38
Thread: Stock springs
06-14-2010, 01:29 PM #1
Stock springs
Hey guys, My cars suspension has been sqeaking alot and I think the problem is the springs. I really dont want to get lowering springs so is there any aftermarket stock size springs? And if there is not when i install the lowering springs do I need adjustable lower control arms or will any aftermarket lca work?
06-14-2010, 02:41 PM #2
Do you have sub-frame connectors? If not, those could tighten up the chassis and possibly get rid of a lot of those squeaks you are hearing.
I don't know about the springs, but if you are lowering the car, it is advisable to get relocation brackets for the LCA's. Depending on how much you lower (most are around 1.25" drop I think), this changes the suspension's geometry. By lowering your vehicle you are changing the LCA angle allowing the rear mounting point to sit higher than the front. The reloc bracket corrects for this. It will also shift the rear end to one side (adjustable PHB).
06-16-2010, 11:49 AM #3
No I dont have subframe connectors yet but my suspension mods are next.
So I should be ok with UMI lca's with lowering springs I just need relocation brackets and adjustable PHB?
Do you know what brand sells the least drop for springs?
06-16-2010, 12:06 PM #4
Strano's are 1.2" drop I believe. Not sure on the others. Well, technically lowering will change your pinion angle too, so an adjustable torque arm would correct for that. Lowering pretty much changes the geometry of every suspension component...I would say an adjustable PHB and LCA with relocation brackets is a good way to go.
Get SFC's!! Probably should be your first suspension mod IMO.
06-17-2010, 12:29 PM #5
06-17-2010, 12:43 PM #6
IMO, even without lowering, LCA relocation brackets help with traction. Therefore, they are even more important when lowering the car.
06-17-2010, 02:00 PM #7
Alright so are the relocation brackets hard to install (or weld in)?
06-17-2010, 02:39 PM #8Exalted Cyclops
- Feb 2007
- San Diego, CA
You need to grease the muffler bearings and add some blinker fluid...
06-17-2010, 02:53 PM #9
06-17-2010, 02:56 PM #10
06-17-2010, 04:26 PM #11
06-17-2010, 04:35 PM #12
06-18-2010, 06:49 PM #13Senior Member
- Jan 2010
- texas
silver- 2000 formula
freshly greased muff bearings and topping off the blinker fluid got me a extra 20 horses
06-18-2010, 08:43 PM #14
06-18-2010, 08:46 PM #15
06-18-2010, 09:09 PM #16
06-21-2010, 09:50 AM #17
Almost every mfg I have ever seen that provides them recommends them to be welded in. My guess would be bolts coming loose. I've never personally seen a set-up with them bolted in so I don't even know how that would work or look like for that matter.
Just seem Smittro's reply as I was typing this...
06-21-2010, 01:40 PM #18
I bought bolt in LCA brackets and then just added a few welds. I prefer bolt ons like the SFc's Mine are bolted on and a few weld beads here and there for added strength and easier to remove later for anything that may happen just have to grind a few weld beads and then unbolt. I have my car lowered with BMR springs and regular LCA and none adj panhard. Have an adj to put in but you cant tell it's not straight if the axle is shifted. Will get around to installing the adj. panhard and lca's again later. I had some UMI non adj laying around and I was in a rush and didn't have time to adj. everything.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
06-21-2010, 02:50 PM #19Exalted Cyclops
- Feb 2007
- San Diego, CA
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
06-23-2010, 04:21 PM #20
can you weld the bolt ons after installing them?
Question: Stock springs
By 98maro in forum General HelpReplies: 8Last Post: 06-23-2010, 03:09 AM -
strano springs vs. stock springs
By TurboTom in forum Suspension and HandlingReplies: 5Last Post: 02-17-2010, 05:39 AM -
LS1 Springs stock
By jrgswhitels1 in forum Parts For Sale / TradeReplies: 3Last Post: 04-19-2008, 11:38 PM -
Stock Springs, Shocks, & Springs
By Bloodta in forum Parts For Sale / TradeReplies: 3Last Post: 05-20-2006, 01:35 PM -
Looking For Stock Springs For My 02 WS6
By Farmer2 in forum Parts Wanted / TradeReplies: 3Last Post: 09-09-2005, 09:37 AM
