Thread: 2003 Silverado SS - Gauges Died
06-14-2010, 07:42 AM #1
I'm trying to help one of the guys I work out with this and I'm coming up short so far. We checked the PCM ground and plugs. I don't really know where to go from there. Electronics are not my specialty.
Back ground: The truck is a 2003 Silverado SS with a VORTEC super charger. The gauges died and we wonder if there's anywhere else we should start looking.
Thanks for any help.Y2K SS A4 Y2Y GU5: 12.96@106-SLP FLO PAC|P&P Stock TB | Pacesetter LT's | TSP Rumbler X Duals | B&M Trans Cooler | Rear Tubular LCA's w/ Relocation Brackets | Tubular PHB | SFC's | Diablo Sport Tuning
06-14-2010, 08:56 AM #2
all the gauges? Is there a serial cable from the cluster to the pcm?
06-14-2010, 01:21 PM #3
There was a TSB for 2003 and 2004 gm trucks for the gauge clusters croaking.
http://www.gm-trucks.com/forums/inde...howtopic=70134
06-14-2010, 07:13 PM #4
Not sure if there's a serial cable. I haven't pulled the cluster yet. I wanted to make sure I wasn't missing anything obvious before I got there. Something we did between unplugging the PCM, and turning all the grounds we could find to the right if they'd turn, the guages came back on but nothing we did seemed loose enough or had a connection that would make me think it would've been a problem. Were watching it for now and trying to get an info we can find. Thanks for the recall info.
06-15-2010, 09:07 AM #5
2018 Tahoe - Silver - OEM
06-15-2010, 02:18 PM #6
It was just the gauges. Everything else worked. We got to look at it in the sunlight today and found the culprit. All is good again. Thanks for the info.
06-15-2010, 03:10 PM #7
06-16-2010, 05:01 PM #8
The positive battery cable.
We were
when it was a bad connection the whole time. Turns out you can tighten a battery cable all you want on a side post battery but if there's corrosion under it...well...lesson learned, don't over look the little things. I was trying not to have to say that we were idiots and the battery cable needed cleaned but you asked.
06-16-2010, 05:34 PM #9
wtt 2003 silverado 22''
By darrellpomes in forum Vehicles For Sale / TradeReplies: 0Last Post: 02-23-2010, 04:06 PM -
2003 Silverado cooling system
By red99ws6 in forum General HelpReplies: 4Last Post: 01-30-2009, 04:37 PM -
2003 Chevy Silverado
By sparky909090 in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-04-2005, 06:02 PM
