Results 1 to 14 of 14
    Nov 2008
    Cheswick, PA
    1998 Camaro Z28
    Just finished lowering, a few ?s HELP please.
    I just installed the SLP lowering kit for the car including Bilstein shocks and springs (eibachs).
    Upon test drive the car handels amazing however when hitting a pot hole or a bump in the road something bottoms out hard on the right rear.
    I have checked the shock and it is good and tight, I did however notice that the bump stops are totally destoryed and on the right side compeletly absent.
    Is this my problem, the bump stop? I jacked up the axle the right side and at full travel I couldnt see it hitting anything. Or is there another common issue that it could be hitting against (I know i need to order an adjustable panhard to center the rear and some LCAs is the lack of them being stronger causing too much travel)? I do have a cat back (magnaflow) however it is good and tight, but I do see a few new scratches where it goes up and over the axle I think that maybe where its hitting but the exhaust is as high as possible.
    Thank you!
    Nov 2008
    Cheswick, PA
    1998 Camaro Z28
    Ok just rechecked
    Its def the the rear end hitting into the exhaust at the axle over
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by Camaro98Z/28 View Post
    Ok just rechecked
    Is your exhaust actually hitting the rear end axle housing or is it hitting the pan hard bar? On mine, it was hitting the pan hard bar. The clearance is tight in that area even on stock ride height depending on what exhaust set-up you have.
    You can try loosening the exhaust band clamps and pull out the exhaust from the Y-pipe to try to create more clearance in this location.
    If it is hitting the pan hard bar, UMI sells a relocation kit for the upper pan hard bar support.
    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    i just lowered my car. replace your bumpstops with smaller ones. Energy suspension has a set, check around on the forums for the part #. I put them on mine to compensate for the car being lower. they're polyurothane
    Jun 2010
    Minneapolis
    2003 Pitch Black ZX3
    Thumbs up
    Thank you!
    Yes I agree. you have a good exhaust. I like the cat back. However you have a big problem with the bump stop. I think you should try to fix it first.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Thank you!
    Even if it's as high as possible, the pipe still can be shifted either forward, or backwards to center the apex of the exhaust pipe over the axle.
    IMO, first replace the bump stops.
    ES pt# 9.9137 is under $20 a pair, and will fit with a slight modification to either the mount holes on the ES BS, or slightly trimming the side of the ES BS.
    Auto Painter RyanJM's Avatar
    Houston, TX
    I just ripped the dryrotted bump stops off and no bottoming out issues.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Member cancam99ss's Avatar
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    bump stops!!
    Quote Originally Posted by RyanJM View Post
    So ust take those rotted things off?
    Junior Member mcnoskyimages's Avatar
    Jun 2010
    DFW
    2002 Camaro Z28
    I may be having the same issue. I can kind of hear something when i pull into my garage. Just that little bit of bump is all I need to set it off. Even going over speed bumps slowly it will do it. From what I have fount the sound is coming from the right side exhaust hanger. Like its sticky or something. There is a bit of play in the rubber and I thought they were supposed to be snug. Im going to check my pipe to see if anything else is rubbing.
    Nov 2008
    Cheswick, PA
    1998 Camaro Z28
    Ok sorry for the long wait but I was rebuilding the whole thing
    Yes the over axle pipe was hitting the rear axle, to fix i found some rubber 3rd gen bump stops installed them and adjusted the exhaust slightly, it has fixed it, however the rear is still a little too bouncy for me. I figured since the shocks and springs were made for eachother this wouldnt be a problem but I do a lot of backroad spirited driving and the rear seems to jump up and down.
    I havent upgraded my panhard and lcas yet, will getting these and obviously adjustables help fix this or should I look into some better rear springs?
    Thanks!
    Member camaross1's Avatar
    Aug 2009
    chesapeake,VA.
    2002 camaro ss
    i took off the stock rubber bump stops on my 2002 camaro ss today and cut off about a inch or so, cut level across then bolted them back on, before i cut them they were real close to the axle housing, i got a 1.5 drop eibach, now got more room, hope that works
    Ca.
    Navy Blue
    1999 Camaro Z28
    If your budget permits you can go with a set of Tokico Illumina rear SA shocks( about $110 ea.) for a 82-92 camaro or rear Koni SA's for a 82-92 camaro (about $125 ea.). either one of these will give you better spring control.
    Nov 2008
    Cheswick, PA
    1998 Camaro Z28
    its the bilsteins causing the problem not the eibachs?!
    Ca.
    Navy Blue
    1999 Camaro Z28
    Well the spring rates on the rear Eibachs don't help keep you off the bumpstops, since there to soft for the decreased suspension(compression) travel. And by the sound of it the Bilsteins shocks just don't have enough rebound to control the springs effectively.
  1. Just finished a rebuild!
    By deuces in forum LT1
    Last Post: 08-10-2009, 08:21 PM
  2. Just finished lowering my car. (56k watch out.)
    By TheKitchenSink in forum Suspension and Handling
    Last Post: 03-13-2007, 08:15 AM
  3. Finished my LT1!! Take A Look!
    By silent101 in forum Camaro / SS
    Last Post: 01-03-2007, 06:37 PM
  4. Finished my T top shades
    By sgt0704 in forum Appearance Section
    Last Post: 08-20-2006, 09:39 PM
  5. car is almost finished
    By Nhra Firebird in forum Almost Anything Goes
    Last Post: 05-16-2006, 01:09 PM
