Results 1 to 11 of 11
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    Water in tail light
    Like it says i have water in my tail light on my 98 z, what di i got to do to fix it?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Most likely remove taillight, let water out of holes in assembly and use clear silicone around the edge of the lens and housing. Let cure for 24 hours and reinstall. Could be done other ways.
    Member stew215's Avatar
    Dec 2009
    Levittown, PA
    Thats what I did and it worked for me.
    Aug 2009
    A, A
    1998 Camaro Z28
    What kind of silicone should i use?
    Dec 2009
    Levittown, PA
    I just picked up a tube at the parts store for like $5. I think it was permitex clear RTV.
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    i drilled 1/8" drain holes in the lowest points in the housings
    Aug 2009
    A, A
    1998 Camaro Z28
    Quote Originally Posted by GULLETT17 View Post
    How does that work for ya?
    I was thinking about doing that.
    Junior Member DannyK's Avatar
    New York
    1997 Camaro z28 Bad Kitty
    I had the same problem, i drilled small holes in the lowest point of the tail light . Works perfect.................
    Muncie, IN
    Quote Originally Posted by zeetwentyeight View Post
    works just fine!
    Aug 2009
    A, A
    1998 Camaro Z28
    works just fine!
    I'm doin it thanks guys
    Member beach cruiser's Avatar
    Aug 2006
    Virginia Beach
    Blue
    2000 WS6 Ram Air Trans Am
    got to take them off to drain them, 3rd time I had to do that, I drilled holes. That was the last time I've touched them.
  1. tail light out
    By bpopham22 in forum Firebird / WS6
    Last Post: 05-06-2011, 07:57 AM
  2. Tail Light, Head Light Lens Cleanup, Body Work Questions
    By MAXX2 in forum Appearance Section
    Last Post: 12-15-2010, 08:15 AM
  3. Tail light
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 02-05-2010, 12:19 PM
  4. Help: More Water - Tail Lights this time
    By Thewilldog in forum General Help
    Last Post: 09-06-2009, 02:06 PM
  5. light up middle tail light bird
    By trans_am7935 in forum Firebird / WS6
    Last Post: 05-28-2009, 07:59 AM
