    Nov 2009
    Wichita Falls Tx
    1998 Trans AM
    ls6 intake manifold coolant problem
    i have a 1998 trans am. i just installed the new weiland ls6 intake but no theres a problem. the old coolant line that went from the radiator thru the throttle body. the new TB doesnt have ha place for it. what do i do with the hose
    NY Representative Vertiviper's Avatar
    Feb 2006
    New York
    99 Trans Am, M6
    What kind of throttle body did you get?
    You can always do a TB bypass and run the line from the radiator straight to the coolant line on the driver side of the front of the intake.
    Senior Member t-rock's Avatar
    pocola oklahoma
    2002 firehawk 94 Z28
    sounds like a easy fix
    you dont live in a climate where that kind of heat is needed to heat your fuel.
    tb bypass is the first thing i do when i get new ls based vehichle.
    Bonner Springs, KS
    99 TA
    +1 on the TB bypass mod, write-up on ls1howto. I had to do the same when I installed my NW tb.
    I just went to the hardware store and picked up a couple brass pieces (barbed on one end and threaded on the other) to go from the 5/16" to 1/4" to connect the two lines.
    Member Dewman's Avatar
    May 2008
    Midland, MI
    2000 Camaro z28
    i just ran one 5/16'' hose and worked out perfect
    Nov 2009
    Wichita Falls Tx
    1998 Trans AM
    Cool
    Quote Originally Posted by Vertiviper View Post
    i have 85mm nitrous express throttle body, and a ported and ploished weiand ls6 intake. thanks for all the help everyone
  1. For Sale: LS1 Intake Manifold,EGR,Coolant Pipi,Stock Exh Manifolds
    By transamtom in forum Parts For Sale / Trade
    Last Post: 08-04-2011, 01:34 AM
  2. LS6 intake manifold and 227 Intake runners
    By IT_SS in forum Internal Engine
    Last Post: 07-07-2009, 02:11 PM
  3. Egr problem......new intake manifold
    By cz28mdn in forum External Engine
    Last Post: 09-04-2008, 07:17 PM
  4. LS1 LS6 Intake Manifold Coolant Pipe Kit
    By splitfinger09 in forum Parts For Sale / Trade
    Last Post: 11-11-2007, 09:53 AM
  5. ls6 intake coolant plugs or extra front coolant pipe?
    By mikes ss in forum External Engine
    Last Post: 12-03-2005, 04:13 PM
