Results 1 to 14 of 14
    Wisconsin
    2001 Camaro SS M6
    Calling out all OEM Speedline Z06 wheel guys!!
    I posted in a seperate thread but figured this needs its own As title states, I have OEM Z06 wheels (17X9.5 and 18X10.5) I know the rears are 58mm offset, what did you need to do to make them fit. I have searched and searched and found tons of misleading information. I heard a 7/16th spacer with a 315 will fit no problem with no pounding or rolling of the lip. Then I heard 1/4 will fit but will hit the lip with a 295 I will be running a 555r 305 tire and they run small but would like a answer. I can get 1/2 inch spacer from a mod for a good price but don't want to rub. I am getting ARP studs regardless just in case Please help!!!!
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Wisconsin
    2001 Camaro SS M6
    I got about 2 hours of net searching for a answer and got none Might just take the bump stop off and go from there When I find the damn solution, I'm going to post it all over the net
    I ran those same size Z06 wheels before I had the CCWs. I had 275s in front and 295s in the rear. I didn't need any spacer, nor would I use a spacer. I am glad you are at least getting hardened ARP studs, but still would not ever use a spacer.
    Wisconsin
    2001 Camaro SS M6
    For Y2K!! So you would rather hammer in the wheel well? I know spacers put stress on the studs, thats why I was going to go hardened but if I should just pound and re-paint/coat my wheel well then I mise well do that. I just don't like the look of a pounded up wheel well (even if you don't see it with the tire on) I dry fitted the wheels and I am for sure hitting the bump stop even without a tire.
    Hmmmm, I don't want to have to hammer either. I didn't have to do any hammering with my Z06 wheels, no rubbing at all. I had to hammer one tiny spot on both sides for the CCWs, but I mean just minimal.
    Wisconsin
    2001 Camaro SS M6
    I fitted just the driver side and it hit the bump stop with about a 1/4 inch to go. I don't know if tires will rub because I don't have them yet Spacer or no spacer, I'm upgrading my brakes and ARP studs so......maybe I'll try a real small spacer Maybe I'll get away with just pounding the bump stop over about 1/4 of a inch and they won't rub
    Maybe I'll sucker Cutlass into doing it for a 12 pack since he lives about 30 minutes away
    Wisconsin
    2001 Camaro SS M6
    The internet is about as good for finding information as a baseball bat is good when taken to the back of the head I get so much counter bullshit stuff off other sites. I'm thinking I'll go ahead and get 1/8 and 1/4 inch spacers and try them out. LS1tech said the way you jack your car up could contribute to it being off, I jacked by my subframes I am thinking of selling this shit box and going with a car that can fit big tires without so much hassle like a Z06 (Yeah right, just ranting there ) I am lost, I wish I lived in a nice place that had car shops unlike this dump state. Hopefully Cutlass can help out when I get ahold of him.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    ok when you jack the car up and let the rear end hang down, the swinging arc of the panhard bar will pull the rearend end over towards the passenger side of the vehicle(bringing the driverside rim closer to the bumpstop)...how much I'm not sure.
    So if you try to put the rear end on a couple jack stands, I think you'll find the rim is no where near the bumpstop.
    Is your car lowered? Are your panhard bar and lower control arms adjustable?
    Madison, WI
    2001 Silverado Z71
    Oh and I forgot to mention, I went out to the garage and looked at my car.With the wheels on the ground the rearend is off center towards the driverside by 1/2" or so. So in my case a bigger wheel and tire combo would have less clearance to the bumpstop on the passenger side. An adjustable panhard bar would fix that.
    Also it looks like an 1/8" to maybe a 1/4" can be ground off the bumpstop and its mount, without much problem, for more clearance if needed
    Wisconsin
    2001 Camaro SS M6
    Maybe I will be fine then It is a adj panhard but I never fucked with it out the box. I am also stock height. I could try the jack stand angle and check that way. Maybe it will help
    EDIT: If shit hits the fan Cutlass and I need your help, I can have your favorite beer within minutes and gas money in hand
    Madison, WI
    2001 Silverado Z71
    I would love to drink...err I mean help. As long as the wife allows me get away from my daddy duties
    Wisconsin
    2001 Camaro SS M6
    I still need to get the tires so it won't be for a couple weeks or so
    Member beach cruiser's Avatar
    Aug 2006
    Virginia Beach
    Blue
    2000 WS6 Ram Air Trans Am
    I'm running 18x10.5 stock Z06 speedlines all the way around my car with 315 Hoosier A6's. The rear has a 5/16 spacer with longer studs, the fronts have 1/4 spacers. I did beat in the fenders a long time ago, but I don't think the new combo would rub as I have it set up now. I also have an adjustable PHR bar to center the rear. My car is a 2000 WS6, the rear fenders may have more "flare" than a camaro, but I'm not 100% sure.
    Wisconsin
    2001 Camaro SS M6
    Quote Originally Posted by beach cruiser View Post
    Thanks for the info
  1. NEEDED: 2002 WS6 Speedline wheel
    By Manicmechanic in forum Wheels and Tires
    Last Post: 09-02-2014, 05:00 PM
  2. Question: Calling all Torquer V2 camshaft guys.
    By blackSS01 in forum Internal Engine
    Last Post: 09-26-2011, 05:43 AM
  3. WTB: 1 17" polished speedline wheel
    By elwood in forum Parts Wanted / Trade
    Last Post: 03-02-2011, 08:01 PM
  4. 1995 Firehawk Speedline Wheel - Center Caps
    By ZuperZport in forum Firebird / WS6
    Last Post: 09-23-2009, 08:38 AM
  5. I'm calling you guys out too......
    By 0rion in forum Corvette
    Last Post: 01-05-2008, 08:01 AM
