Thread: fuse ????
06-10-2010, 06:03 PM #1Junior Member
- Feb 2006
- houston
pewter- 2001 camaro z28
fuse ????
if im using a fusetapper kit, which leg of the fuse should i use?? or does it matter??? reason i ask , it states to use the cold side of the fuse on the kit..i need help finding out which is the cold side.
any one???Last edited by z28_81; 06-11-2010 at 03:49 AM.
06-11-2010, 03:49 AM #2Junior Member
- Feb 2006
- houston
any one..................
06-11-2010, 05:51 AM #3Member
- Northern Virginia
BLACK- 2000 Camaro SS
Do you have a test light? Turn on the ignition, if necessary, to make sure power is going to the fuse you are tapping into, remove the fuse, then use a 12V test light on each side. The side that doesn't have power is the "cold" side. The reason you want to use the "cold" side is so that whatever you are hooking up to the fuse tapper will still be protected by the fuse.
06-11-2010, 07:05 AM #4Junior Member
- Feb 2006
- houston
06-11-2010, 07:20 AM #5Member
- Northern Virginia
You should be able to find one at most auto parts stores. Ask 'em for a circuit tester. Something like these
06-13-2010, 12:46 PM #6Junior Member
- Feb 2006
- houston
ABS Fuse HELP!
By JayDe in forum General HelpReplies: 5Last Post: 07-16-2009, 10:20 AM -
Cig/Acc Fuse
By ls1camino in forum Stereo and ElectronicsReplies: 0Last Post: 04-25-2008, 05:07 PM -
What is this fuse for ?
By Speedy_Gonzales in forum External EngineReplies: 5Last Post: 02-20-2008, 06:46 PM -
Fuse Box
By 1 badblack transam 01 in forum Firebird / WS6Replies: 0Last Post: 03-17-2006, 02:06 PM -
ENG SEN fuse
By ss~zoso~ss in forum Camaro / SSReplies: 5Last Post: 09-04-2005, 03:51 PM
