Results 1 to 3 of 3
Thread: Clutch line fitting
06-08-2010, 02:37 PM #1
Clutch line fitting
I bought a McLeod adjustable clutch master cylinder off ebay. It barely looks used, but is missing the fitting that holds the feed line. I called McLeod, but I might as well send smoke signals. Still waiting for someone to call back.
If need be I could use a banjo fitting with a nipple end, but I'm not sure if a nipple fitting and clamp would hold up? Not sure what kind of pressure is in the line. If I go this route, I could eliminate the connection that needs the "drill mod". Any advice?
06-10-2010, 02:36 PM #2Senior Member
- Feb 2006
- Orange County, NY
If this is it then it looks like just a basic brass elbow. http://www.summitracing.com/parts/MCL-139001/?rtype=10
06-10-2010, 02:47 PM #3
Yes, that's the unit. I wasn't very clear on which fitting I needed. I said the feed line, but I meant the line that feeds the slave cylinder. The one on top that connects to the resevoir is there. The one on the end is missing, and it's a 10 mm (I think) banjo fitting. Still never heard back from Mcleod, so I did the drill mod and reinstalled the stocker. I'll be selling the Mcleod. If the stock unit goes, I'll install a Tick unit.
Trans Line Fitting Size
By TA98 in forum General HelpReplies: 3Last Post: 01-24-2012, 06:45 PM -
Clutch line leaking
By papim5 in forum General HelpReplies: 1Last Post: 01-25-2011, 03:06 AM -
Anyone know where to buy a clutch line?
By Frankthetank in forum Almost Anything GoesReplies: 4Last Post: 10-11-2009, 04:35 PM -
Question: t-fitting on gas line???
By COJO_24 in forum General HelpReplies: 5Last Post: 08-11-2008, 08:37 PM -
WTB Clutch Line
By wankel22hybrid in forum Parts Wanted / TradeReplies: 0Last Post: 12-07-2005, 12:35 PM
