    Junior Member carnut7202's Avatar
    May 2010
    2002 t/a ws6,1972chevelle
    Window motor problem any one???
    Ok so not only are my door panels cracked the window motors are going out to? Has any one had to replace them. I called a few dealerships here and got qotes. One wanted 57.00 for the motor 373. to install the other one wanted 67.00 for the motor and 270 to install go figure. I thought about doing it my self but i herad they are put in there with 1/4" rivets. that sound like that would be a pain. also i have heard that do to a lovely gm fubar design once agian that the motors themself do not get enough power and this why they go down slow. Does any one know if that is true. I have seen kits that say they fix this problem but do the work thanks for any advice guys
    Most auto parts stores sell them for ~$50, here is a write up so you can do it yourself and save a few hundred bucks.
    http://shbox.com/page/windowmotor.html
    May 2010
    thanks y2k
    Greensboro, NC
    2002 Trans Am WS6 M6
    To fix that pesky screw up by GM hit up the Autotrix guys. They have a wiring kit to fix the passenger window. Might as well take care of it while replacing the motor.
    http://www.ls1.com/forums/showthread...ger+window+fix
    Member Mieux97's Avatar
    Chicago
    99 Pontiac Trans Am #2466
    Why not just buy the entire window regulator?
    Member knightryda01's Avatar
    May 2008
    Michigan
    midnight blue
    2000 Pontiac ram air ws-6
    I just replaced mine. Pretty easy.
    Member lopedawg's Avatar
    Joliet, IL
    yellow/black
    2002 Trans Am CETA
    Though I have not used autotrix I've read nothing but good things about them.
    As for the window motors, they can be easily replaced with basic tools. If you follow the instructions on the link posted in the second post you'll have no trouble at all.
    02 CETA #654 7800 miles
    09 G8 GT liquid red, sport/premium/sunroof red/black int
    07 Tahoe LS
    ...you'll know it's me when I come through your town
    I'm gonna ride around in style, I'm gonna drive everybody wild
    'cause I'll have the only one there is around
    May 2010
    well thanks guys i just did the fix the crack door pannel mod to day i thought about attemting the window it did not happen lol drilling out the riverts it what scars me plus i am a big guy i didnt think i could get my arm in there oh well so is life
    Sponsor autotrix's Avatar
    Tulsa, OK
    Here is our window motor replacement guide:
    www.autotrix.net/install
    Click the window motor replacement link at the top of the page.
    Please consider our kit for your passenger window, it will keep you out of that door panel for a long time
    Got passenger window problems?
    http://www.autotrix.net
    **Window Express Down Modules now availible**
    http://www.autotrix.net/products.html
    What I do? SHines-IT's Avatar
    Jun 2009
    FL, USA
    2011 Prius
    I replaced one in the 98 Trans Am, last year... Cost $35 for the motor. It was not really that hard, just annoying... I would try to find an smaller trustworthy company to install.
    Junior Member knightbird98's Avatar
    Dec 2009
    Johnstown
    i just replaced my passenger side and it was kinda tough took me about 2 hours
    i just drilled out those rivets
    i got the motor for 50 bucks at checker/o'rieley
    Jun 2009
    FL, USA
    2011 Prius
    Quote Originally Posted by knightbird98 View Post
    The tight spaces and hard to see makes it hard. If your not careful in there you can easily take a finger off and I did not use those directions, would have helped... But I would try to find a small garage, I would have gladdly paid $100 for someone to do it, lol.
  1. Window Motor
    By Z28boy2000 in forum Camaro / SS
    Last Post: 08-11-2009, 02:18 PM
  2. window motor/switch problem
    By silplu83 in forum General Help
    Last Post: 06-08-2008, 03:07 PM
  3. window motor
    By N20LT4 in forum LT1
    Last Post: 08-29-2007, 07:46 AM
  4. Window Motor?????
    By GreenBirdman in forum General Help
    Last Post: 02-20-2007, 02:33 PM
  5. Window Motor Mod??
    By CamaroFan71 in forum General Help
    Last Post: 10-12-2006, 07:36 PM
