Results 1 to 18 of 18
Thread: Oil in my TB?
    NeW YoRk
    2001 ws6
    Oil in my TB?
    Took my PP TB out after about 30 miles because it wasnt idling right to replace it with the stock one and there was a thin layer of oil in my TB.......I dont think this is normal? Can anyone explain this?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i always get a very very thin layer of oil(either from the filter or the engine) around the blade. with the little amount of mileage you had on it ..i dont think you should have got that much.
    Arizona
    Ya normally I would say it's the PCV system without a catch can,,,but 30 miles???
    NeW YoRk
    2001 ws6
    it wasnt much, but enough to notice......
    K&N or similar? Is so, had you recently serviced the filter?
    NeW YoRk
    2001 ws6
    had the k&n in there for about 2k miles, havent re-oiled it
    most likely just oil vapor making it's way into there...put a catch can on it.
    Arizona
    That's what I would say. I had oil actually making it past the throttle body and puddling in the bellow.
    NeW YoRk
    2001 ws6
    so it wont hurt anything for a little while? i dont have the money for a catch can right now
    Arizona
    Doesn't cause drivability problems per say if that's what you mean.
    It will however coat the inside of your intake, as well as the intake valves. It also dilutes the fuel mixture inside the combustion chamber.
    I think Orion had a write up on how to make a catch can for cheap at the local hardware store.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    yep it only takes one WOT run to push oil vapor back through the PCV system and onto the TB
    you can make one out of an air line water separator. Might not hold as much as some of the aftermarket catch cans but will still work. You can buy them at any place that sells air compressors and things like that such as Lowe's or Home Depot.
    NeW YoRk
    2001 ws6
    thanks for the info guys!
    2000 Camaro B4C
    anyone got a write up on how exactly to make one and ect....i'd be interested to try it out
    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    +1. i recently did some regular maintenence work and found some oil around the blade. Anyone have the link to the write up?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Where does that valve go? Between the catch can and the intake, NOT between the valve covers and the catch can? The water seperator is directional right?
    (sorry to threadjack, but seems to be good info for all)
    after the pcv and before the intake....make the arrow point towards the intake.
    Not really a write up out there that I know of, or maybe there was and I've forgot about it.Pretty straightforward to do. You just put the seperator inline between the pcv valve and the intake.
    11's "CLUB" SS SLP2's Avatar
    Silsbee, Tx
    Y2K Camero SS
    LS1 TO LS6 PVC conv
    http://www.ls1howto.com/index.php?article=18
    works best
    Johnny
    Y2K SS (SLP #239)
    Completly STOCK heads/bore/stroke/weight
    & NOTHING else ---is stock
    "NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
    ps: I am not soliticing work as I am retired
    >>>info on alignments
    http://www.jgruggles.com
